Hot Rods How much does a 392 Hemi really weigh ?
Discussion in 'The Hokey Ass Message Board' started by 73RR, Sep 1, 2020.
  1. 73RR
    73RR
    Probably not as much as you thought: Add for carb, flywheel distributor.
    The customer kept the oem iron water pump ***embly but opted for the alum intake.
  2. 700-800 lbs.
    would be my guess .
    the 261 in my 50 Chevy weighed 600 some odd pounds without all the bolt on goodies.
    fauj likes this.
  3. RmK57
    RmK57
  4. das858
    das858
    623 lb isn't bad at all !
  5. ekimneirbo
    ekimneirbo
    I think someone filled the valve covers with helium.....:D
    Tim, j-jock, kidcampbell71 and 5 others like this.
  6. bobscogin
    bobscogin
    You sure that scales reading pounds and not kilograms?:)
    Bob
    Beanscoot and VANDENPLAS like this.
  7. Budget36
    Budget36
    Love the guesstimates. I wonder if that's with/without a factory iron intake or a flywheel?
  8. wraymen
    wraymen
    I had to see what that would be in lbs.
    1,373.4798934
    On a side note, I’ve been told a Cadillac 500 weighs 625 lbs.
  9. Hemi Joel
    Hemi Joel
    from Minnesota
    Here is mine at 645 lbs. Not stock, it has weight saving aluminum heads and intake, no water pump, no exhaust, but extra weight with the 8 carbs and the 8 counterweight billet stroker crank. hemi weight.jpg hemi weight.jpg hemi on scale rear.jpg
    mgtstumpy, Tim, kidcampbell71 and 7 others like this.
  10. 1946caddy
    1946caddy
    from washington
    Completely stock, 745 lbs.
  11. panhead_pete
    panhead_pete
    Feels like 500 of those lbs are in the heads when you need to remove them :)
    Stan Back, scotty t and Bondo Slinger like this.
  12. RmK57
    RmK57
    426 Hemi weighs 843 lbs. They don't call them an elephant for nothing.
  13. Hnstray
    Hnstray
    from Quincy, IL
    The figure I remember from years (decades) ago, published in Hot Rod Magazine’s specialty book, “The Complete Book On Engine Swapping” *.....was 765 lbs fully dressed. You could shave lots of pounds by using an aluminum intake and various other weight saving mods.
    * may be exactly correct....or a close approximation, but close enough to search for one if you are looking.
    Dodge hemis were about 645 lbs or so, and Desoto sort of split the difference. In 1961 at the ripe old age of 17, I pulled a 331/M6 semi-auto from a ‘51 New Yorker and installed the combo in my ‘53 Plymouth Convertible. In hindsight, kinda amateurish, but that’s what I was then, and am now, but I did get it running and driving. Several ‘concessions’ made it impractical to operate regularly, so I yanked the hemi and reinstalled the flatty six. But I did learn a lot from the exercise. ........oh, my point in relating this story is....that was one heavy sum*****!
    Ray
    rockable, Baumi, scotty t and 2 others like this.
  14. swifty
    swifty
    I ***ume that 392 Hemis only came in Chrysler and Imperial as Dodge had the Red Ram, DeSoto had their version and Plymouth only had Polys. Were Chrysler and Imperial automatic only and if so then Flywheel weight would not be counted in the engine weight?
  15. gimpyshotrods
    gimpyshotrods
    You got that right, boy-o!
    Stan Back, panhead_pete and Just Gary like this.
  16. Stovebolt
    Stovebolt
    Just so we can get a comparison - how much does a flathead, a small block, an Olds (331) and a nailhead weigh?
    Or do we need a new thread listing all the popular hot rod engines, and their respective dimensions and weight?
    kevinrevin likes this.
  17. clem
    clem
    flathead and sbc. in the vicinity of 525 - 535 lbs respectively. - source HAMB forum........
  18. bobscogin
    bobscogin
  19. Hnstray
    Hnstray
    from Quincy, IL
    bobscogin likes this.
  20. A Boner
    A Boner
    Wonder what a similarly equipped flathead with Ardun heads weighs compared to the Hemi?
  21. sunbeam
    sunbeam
    My 270 dodge with fabed intake and aluminum Chevy water pump with aluminum flywheel weighs 555 lbs
  22. 4tford
    4tford
    Changing the water pump to a chevy and using the aluminum intake takes well over 100 lbs off the engine bring the weight close to the RB Chrysler engines.
    Stan Back likes this.
  23. Gotgas
    Gotgas
    from DFW USA
    Dodge - 645 lbs
    Desoto - 675 lbs
    Chrysler - 740 lbs
    Hot Rod Engines
    By the Editors of HRM, 1967
    It's not clear if these are short- or tall-deck variants, or what level of dress these weights are for.
    The article also mentions that during the fuel ban, blown Chevys were around 800lbs while the blown Chryslers were around 1300. :eek: Must have been before Donovan and Hot Heads came around...
    Hnstray likes this.
  24. 73RR
    73RR
    Interesting that the 'charts' all show an additional 100lbs or more.
    I 'spose that the iron intake, generator and torque converter would equal that.
    The Cad 500 was mentioned by wraymen; I have 2 in the shop and they do tip the scale right at 625.
  25. willys36
    willys36
    More than a little, less than a lot I reckon.
  26. 6sally6
    6sally6
    The same guys that pull the hemi's heads (while still in the car) could get .....equal "Hemi-rrhoids" pulling the intake off a stock Ford FE engine. Holy-moly!:eek:
    6sally6
    mgtstumpy, 56don, vtx1800 and 3 others like this.
  27. 1934coupe
    1934coupe
    Panhead that's why I only deal in SBC. I have felt your pain! And I do it single handedly.
    Pat
  28. sunbeam
    sunbeam
    It is amazing what 15 years will do Cadillac v8 went from 331 to 500 cu inches and lost 65 pounds.
  29. 1946caddy
    1946caddy
    from washington
  30. The37Kid
    The37Kid
    My 354 came with a cast iron transmission and fell through the plywood deck on my trailer, wonder what that total weight was. Bob
    56don and Baumi like this.
