How Much Flake
Discussion in 'The Hokey Ass Message Board' started by Camm, Jan 5, 2009.
  1. Camm
    Camm
    To do a roof on a 1954 Ford two door sedan ????????????:confused:
  2. CHOPSHOP
    CHOPSHOP
    from Malden,MA
    how 'flaky' do you want it?
  3. skyrodder
    skyrodder
    as much or as little as you want...
  4. Camm
    Camm
    Do i start with a pound ??? I really don't know how far this stuff goes. And yes i want it pretty flakey.
  5. hotrod-Linkin
    hotrod-Linkin
    start with a little,spray a test panel,add if needed....don't experiment on car .an old fender or hood will work.
  6. RodStRace
    RodStRace
    enough that the chip stands up....
  7. hiboy32
    hiboy32
    from Omaha, NE
  8. fuzzy bunny
    fuzzy bunny
    I used 16 ounces to do my whole van...
  9. kustomclassics
    kustomclassics
    It also depends on what gun/tip your using also the size of the flake.
  10. SinisterCustom
    SinisterCustom
    Depends.....I like to spray a metallic base coat similiar to the color of flake I'm gonna shoot, so some of the base shows through. And I like the smaller flakes...seem more brilliant. Usually 1 to 1 1/2 jars of Roth flake per roof.
  11. LUCIFR
    LUCIFR
    from Seattle
    no thats funny sh*t
  12. Mike The Photo Guy
    Mike The Photo Guy
    You can judge a man by the size of his flakes. Step up brother! This is Kirk Hanning's truck. Kirk shot it with an undercoating gun.
    Mike TPG
  13. loveoftiki
    loveoftiki
    from Livonia,Mi
    A rocker shutz gun sprays flake well A cheap 20 dollar syphon gun with a hogged out tip works well too
  14. NotStockPhoto
    NotStockPhoto
    The roof on my van has 15 ounces its the biggest you can spray out of a regular gun
  15. hemi
    hemi
    I always used my primer gun... and too much is never enough... don't be shy with it.
  16. oneshotkustoms
    oneshotkustoms
    from joliet il
    as much as you want here is a 63 caddy I did for my buddy Bobby !!!!!! and my 52 I did the whole car
  17. Kirk Hanning
    Kirk Hanning
    Seeing that I have never sprayed flake before I used about 6 ounces on my truck posted above. That's 1 and 1/2 jars of Roth flake. I mixed 1 solid color of flake and 1 trippin' color of flake for a better affect. Both were made by Roth Flake. Spray the flake in the House of Kolor Intercoat clear (sg150). I used 4 coats of Cinnamon pearl base with 8 coats of flake then 4 coats of standard HOK clear. Wait at least a week to color sand seeing the build is so high. Not saying this is the right way to so it but it worked for me. I used a standard DeVilbiss gravity feed gun with a 2.2 tip. After the 5th coat of flake it just absolutely jumped out at you. So I thought more would be even better.
    Thanks for posting Mike much appreciated. Yeah, I'm computer illiterate.
  18. NotStockPhoto
    NotStockPhoto
    Use a heavy mettalic base and you wont have to use as much either
  19. NotStockPhoto
    NotStockPhoto
    I am a big fan of your truck by the way that thing is awesome
  20. Church
    Church
    from South Bay
    I say if you are gonna flake it.......the FLAKE it. None of this salt and pepper ****.
  21. Camm
    Camm
    I'm going to use the big 2.5 flake in orange. Can i use a black base coat with the orange ? The local paint store sold me top coat clear, said it was better than inter coat clear because it laid down the flake better. Any comments about this ???? I've shot a lot of cars in the past, just don't know **** about flake yet.......Thanks for the info guys.........:confused:
  22. Mike The Photo Guy
    Mike The Photo Guy
    I'm right with you Acrochicken. Kirk's truck is on of my favorites. The suspension is really cool. I like everything about this truck. Here's a few shots of the suspension detail. This truck drives like a sports car.
    Mike TPG
  23. SlowandLow63
    SlowandLow63
    from Central NJ
    I disagree. I feel just the opposite. The intercoat sets up faster and thus suspends the flake quicker rather than letting it sag. Think of it as a vehicle to glue the flake to the car, rather than an actual layer. Plus, with all the clear on top you'll need to bury the flake, I'd want to minimize on film build wherever I could.
  24. SinisterCustom
    SinisterCustom
    I agree with Bill........plus intercoat is way cheaper than the clear and catalyst too.....
    I only use straight clear for burying flake, graphics, whatever.....intercoat for everything underneath.
  25. Camm
    Camm
    Thanks for the info.
  26. FinnishFireball
    FinnishFireball
    Exactly, less ain't more when it comes to flake
  27. 66Newport
    66Newport
    I agree the more flake the better. I was told if you contact DeVilbliss you can order a 2.8mm tip. That is basically a water hose, you should be able to spray damn near anything out of it! But definately spray a test panel first. I can't wait to get to do mine, I will be ordering a pound to start!
  28. langy
    langy
    That truck is gorgous, Any more pics ???
  29. SlowandLow63
    SlowandLow63
    from Central NJ
    You don't need a 2.8 tip for flake, thats ridiculous. I have a 2.0 that I use for the big stuff and thats plenty. For regular and mini I use my primer gun with a 1.7.
  30. 66Newport
    66Newport
    What do you use for an agitator to keep the flake from clogging up the gun? Curious, I haven't shot REAL big flake, but I am wanting to on my current project. I read most of the companies selling the flake suggest a 2.2 or 2.5 tip. :confused:
