How much ground clearance do you need?
Discussion in 'The Hokey Ass Message Board' started by Satsop55, Dec 11, 2009.
  1. Satsop55
    Satsop55
    from Satsop, WA
    I am building a '32 Ford Roadster and am in the process of fabbing up engine mounts for the '56 265. What is a good amount of ground clearance for the oil pan? I'd like to keep the car as low as possible.. Durant mono leaf in front and Superslide reversed eyes in the rear.
    Thanks, Jason
  2. 61TBird
    61TBird
    Keep it above the lowest point of your wheels.......
  3. skwurl
    skwurl
    Yup
  4. mikeco
    mikeco
    from virginia
    Best advice you will get!
  5. brokenspoke
    brokenspoke
    I think its called the scrub line
  6. superbeeme
    superbeeme
    from georgia
    How much ground do you have to clear???
  7. I would add an inch or two to the scrub line.
  8. brokenspoke
    brokenspoke
    When all tires are flat you dont want any part of the car touching the ground....except the rims
  9. 29nash
    29nash
    from colorado
    I would like an inch or two above the bottom of the axle beam. Them speed bumps in the trailer park are a *****.:eek:
  10. Satsop55
    Satsop55
    from Satsop, WA
    Wow.. Great advice!
