Technical How much is enough ( boring)
Discussion in 'Traditional Hot Rods' started by Hombre, Nov 10, 2016.
  1. -Brent-
    -Brent-
    I don't know much about much… but have you considered sleeving it and running it at a stock bore?
  2. andyg
    andyg
    That fence poses no threat to the average man with 32" inseam!
    Truck64 likes this.
  3. Hombre
    Hombre
    Brent, That is something that I actually looked at. There are a couple of schools of thought on sleeving, I had a couple of machine shops ( there are damn hard to find here in Alabama) that said they would not install eight sleeves as it would distort the block. I personally don't have a clue if that is true or not. The other is cost, sleeves at a minimum of $100 a pop means I would have $800 just in the bare block. Not saying that is not doable all things considered but it ain't cheap, Is it?
    -Brent- likes this.
  4. gimpyshotrods
    gimpyshotrods
    Speak for yourself, beanpole.
    Truck64 likes this.
  5. CNC-Dude
    CNC-Dude
    Sleeving more than 2 cylinders on the same bank is not a good idea. Since the block is already that large a bore, there is not much metal left to remain once you bore to sleeve them, and you'll likely bore into the water jackets on the cylinders to install sleeves, and that wouldn't be good for that many sleeves.
    -Brent- likes this.
  6. sounds like the story on my 331 hemi
    was 'rebuilt' years before I got it but never ran
    glad I tore it down cause it was missing the pick up screen on the oil pump
    it had been bored and had a fresh crank grind but old cam bearings
    and had a new set of forged pistons
    luckily it wasn't punched as hard as yours is
    as far as sleeves, some folks claim that it ads strength to the block
    have you called these folks about the block?
    http://www.performancespecialtiesinc.com/contact-us/
    he will give you an honest answer
    Hombre likes this.
  7. CNC-Dude
    CNC-Dude
    There are several good performance and race shops in Huntsville and Birmingham. I worked in a race shop in North Georgia close to you and in my experience, it never strengthens the block by adding sleeves, it removes too much of the parent metal to support the sleeve you install back into it. They can also double check your sonic checking results to see if your in good shape or worse shape than what you're thinking also.
    Hombre likes this.
  8. van Dyck
    van Dyck
    My 324 Olds is running .125" overbore and JE forged 11:1 full skirts on .008" cylinder wall clearance. A bit noisy on initial start-up, so a warm-up is necessary. 93octane. MSD 6a box road test set timing eliminates detonation yet keeps the engine lively. In a 2340# roadster.
    As others have said, "run it!"
    And I don't torture my cars like I used to.
    Hombre likes this.
