How much is this worth?!? 1946 Chevy Pickup
Discussion in 'The Hokey Ass Message Board' started by justnicholas, Jun 8, 2010.
  1. justnicholas
    justnicholas
    I found this on craigslist awhile ago and the guy agreed to sell for what I think is a decent price. I just want to know what you guys think since your the experts in my opinion. Its a 1946 Chevy Pickup on a 1990 S10 frame. Its got a 350 and an auto tranny. He did most of the work himself and built the front end thus there is no bottom grill part. Its chopped 3 inches and also channelled. He said it does have some over heating problems that would need to be adressed.
    I am would love to use it as a daily driver/work truck. Lemme know what you guys think and how much its worth.
    Thanks!
    I really appreciate you guys cause you know your stuff.
  2. 383 240z
    383 240z
    Any pics, condition of the body? something to base a price on is helpfull. Keith
  3. justnicholas
    justnicholas
    Here are some pics he sent me. He was saying he did all the body work, I donnu if that means metal or lots of bondo, but there are dings and scratches but he said its pretty good.
  4. wvenfield
    wvenfield
    It would all depend on what needs addressed to solve the overheating problems.
    Maybe it doesn't have a lower grill and heating problems because it's not getting enough air flow. Maybe a fan would work. Maybe not.
  5. rick finch
    rick finch
    After seeing the photo of the engine compartment, I wouldn't touch that thing with a 10' pole.....
  6. ZomBrian
    ZomBrian
    from in IN
    Maybe the overheating issues are because the grille used to be a lot more open and the pipes that are in place of the hood vents are not helping the heat escape.
    Here is a pic from the net of what it should look like were it stock-ish.
  7. brad chevy
    brad chevy
    What price is he asking for the truck?,by the looks of the picture with the hood up not a very good paint job,and the overheating could probably be cured with a shroud and better fan.
  8. It's gonna overheat the way he has it set up. their is no where to draw air from or no where for it if go out of the engine compartment, it needs to breathe. make sure the radiator is big enough to cool it, and get rid of that worthless flex fan and run a hd clutch fan with a 7 or 8 blade fan and put a shroud on it, that should help a bunch, but you still need to get incoming air to the radiator, either make a scoop setup under the front fender/grill or put the stock grill back in it. then make sure their is room around the motor, hood vents so the hot air has someplace to go.
  9. mattrunner
    mattrunner
    from uk
    think the overheating might be a problem here but overall look ok.
  10. zgears
    zgears
    looks super sloppy...
  11. 1946chevytruck
    1946chevytruck
    from london ,ky
    about $5000- $9500 maybe a little more or less
  12. justnicholas
    justnicholas
    Here are some more pictures. I assume I would have to drill holes in the front or put some kind of grill to get air to it, but that doesn't seem too big. I don't care for the paint color too much but its not that big of a deal to me.
  13. justnicholas
    justnicholas
    Thanks for actually putting up numbers. I am pretty sure I can get it for around $5000.
  14. motohack
    motohack
    from NorCal
    Ditto!
  15. 1946chevytruck
    1946chevytruck
    from london ,ky
    what is he a sking for it
  16. 1946chevytruck
    1946chevytruck
    from london ,ky
    $5000 is a good price i have alot more then at in my 46 chevy pickup and it is in pieces
  17. THE_DUDE
    THE_DUDE
    5 gs sounds a bit steep.... But what elese are ya gonna find for that kinda money
  18. ZomBrian
    ZomBrian
    from in IN
    I personally wouldn't give $5K for it, there is just too much that I'd want to change. However, if you just want it as a daily driver and can live with the modifications it has I say go for it.
  19. THE_DUDE
    THE_DUDE
    You cali guys get scared too easy... I see that and I just wanna offer less cash. The s10 frame and that wacky grill scare me
  20. Truckedup
    Truckedup
    Is that the truck listed for 8500 bucks?What you're getting is more or less is a 350 powered S10 with an early body instead of an S-10 body.Check it out ,make sure it's all done nicely,it's your money.
  21. justnicholas
    justnicholas
    He was asking $8500 but it was on craigslist for awhile so I decided to shoot him a low offer and he said since I was a young kid he and wanted to drive it, he was more willing to part with it. Which probably means he hasn't had any offers.
  22. justnicholas
    justnicholas
    I know lots of people are not fans of S10 frames on the HAMB but I think it would make things easier to work with and a better driver. Honestly, I don't know a whole lot about rods, get lots of help from my dad and being able to get new parts for fairly cheap prices wouldn't hurt me.
    The grill set up kind looks funky to me and not a huge fan that the front end isn't original so I donnu how I feel about that. I think I would want to change it somehow but not sure yet.
  23. rottenleonard
    rottenleonard
    5-G's doesn't get much anymore, I'll bet you couldn't do the work yourself and get it to that condidtion for less. Either you or some one competent should look at it close to make sure it's not a death trap.
    Good luck Robert
  24. Truckedup
    Truckedup
    An S10 frame swap can make a nicer driver...or not.....depends on your type of driving.
    Sounds like you want the truck,sounds like the seller has given you price you like...I think you don't need to listen to us,go buy it!;)
  25. 29nash
    29nash
    from colorado
    Clear WA title? That's worth a few hundred. Whatever the hood, fenders, doors, grille, motor, tranny, rear axle, and bed are worth. Motor overheats, its worth a couple of hundred, maybe. Tranny works its worth three hundred. Chassis is worth a couple of hundred. You are going to want to repaint it anyhow. Add it up.
  26. 1946chevytruck
    1946chevytruck
    from london ,ky
    my 46 chevy pickup is ona 77 chevy short bed frame and it has a 350 motor and 400 tubro trans. i have a 46 chevy pickup that is all org.thansk
  27. propwash
    propwash
    from Las Vegas
    Also...if he starts telling you the truck is in Kansas, and he's overseas, or on a job in Canada, but he's going to do the transaction using Ebay's Buyer's Protection Plan, tell him he needs to go wait for the next turnip truck, cuz you just ain't his guy.
    Make sure he has CLEAR title to the vehicle and ask him whether it's titled as a 46 Chev pickup or an S10 - cuz you just may have some DMV issues and some smog issues if it's an S10 title.
    Two things to always remember - Buyer Beware and protect yourself at all times.
    dj
  28. Antny
    Antny
    from Noo Yawk
    If everything is legit and it's a safe vehicle, I'd say between $3,500 and $5,000 would be considered a good buy for that truck.
  29. wolfers
    wolfers
    Amen to that brother.
  30. PhilJohnson
    PhilJohnson
    'Bout what I was thinkin depending on how rough the body is. If it was me though I'd change that awful looking steering column and steering wheel out for something more vintage looking.
