Talking rpm's here. What kind of rpm's can these 8ba motors turn without throwing rods out the side of it? Ive got a newly rebuilt flatty with max-1 cam, isky springs, stainless valves, 3 ring ross pistons and arp main bolts and rod nuts. Stock rods, and stock crank, fully balanced. What am I safe to rev er' to if i decide to take it to the strip someday? Sound amazing with the unbaffeled zoomies btw! Just let me know what ur guys' take is on this.
whats the cam rated for it tells you on the spec sheet , Alsow the intake makes a difference the specs are below . Its made for low end power Hot valve lash .014" intake and exhaust .364" lift, intake and exhaust 249-deg advertised duration intake and exhaust 226-deg duration @ .050 intake and exhaust 111-deg LC
