How much is too much?
Discussion in 'The Hokey Ass Message Board' started by BLUDICE, Feb 24, 2012.
  1. BLUDICE
    BLUDICE
    I want to drop the front end a little more - already cut 1 full coil (stock springs) - I heard once that you should not cut too much of the second coil cause a little is alot on the second coil. Should I cut a quarter of a coil or half to start and what will I end up with?
  2. Master of None
    Master of None
    If your really unsure of how much drop you want, I would only do a quarter at a time. When I cut coils for client cars I only do a half a coil at a time.
  3. Jalopy Joker
    Jalopy Joker
    stop and search here for ways to lower frontend on Shoe Box Fords without it riding like it has no springs by cutting too much.
  4. jack orchard
    jack orchard
    go slow - 1/4 at a time. it took me 3 sets of springs to learn this many years ago.
  5. fastcar1953
    fastcar1953
    ford areostar coils will drop it 2.5 inches. hope it helps
  6. SUCIO
    SUCIO
    x2^^ Plus you will notice better handling with the aerostar springs up front.
  7. Smokey2
    Smokey2
    Boy, Oh Boy !
    Doin' backflips to learn 'bout the Aerostar Coils useage.
    I knew if I stayed up late enough tonite (this morning ), I learnt Sumthin good.........................Thanks
    _______________________________________________________ :cool:
    Ole Smoke'
    In tha Great Smokey Mts. of Tenn.
    _________________________________________________________
    "Happy Motoring, Starts At The ESSO Sign"
  8. Another note in addition to creeping up on your final ride height: After dropping the car down, roll it back and forth several feet while bouncing the suspension - or better yet drive it around the block, you'll thank me later.
  9. BLUDICE
    BLUDICE
    How much of a drop should I expect from a 1/4" cut of coil.
  10. shocker998md
    shocker998md
    If you havent driven the car yet dont cut any more. The springs will settle some. Give it a week or two of driving and then see if you need to cut 1/4 to a 1/2. If you mess up and cut too much step up to the aerostar coils.
