How much should a 283 cost?
Discussion in 'The Hokey Ass Message Board' started by areffert, Feb 2, 2006.
  1. areffert
    areffert
    from Pittsburgh
    I was recently offered a Chevy 283. It is a complete motor, basically stock aside from the cam. It has a new 600 cfm carb. I was wondering, what is a reasonable price?
  2. Little Wing
    Little Wing
    from Northeast
    What ever you can afford ,really and it depends basic and depends on where you get it
  3. AHotRod
    AHotRod
    If it's a correctly fresh built engine, it's worth up to $1,000.00
  4. areffert
    areffert
    from Pittsburgh
    The engine isn't fresh, but I will be able to hear it run. The seller is pulling it out of his 57 Chevy in favor of a 327. He says (of course) that it is a good motor.
  5. a 283 that needs a total rebuild can go for $50-$100. to do a basic rebuild with with a bore job , new pistons/rings , heads redone ,all new cam/lifters/timing chain/oil pump , clean the block and magnaflux ,etc can cost about $1200 -$1400
    so i'd say somewhere inbetween
  6. squirrel
    Drive it around, listen close, see if it smokes on startup or after decellerating down a hill, do a compression check, etc. If he already has it out of the car it's worth no more than a couple hundred, because you can't do these things.
  7. blown240
    blown240
    from So-cal
    I had a 57 283 given to me. It had had the rotating ***embly and a set of early Fuelie heads. Neither had been run in over 10 years.
    I sold the heads for $500 and the rest for $50.
  8. Nekronomicon
    Nekronomicon
    Heres some inspiration...
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If it runs good, doesn't smoke or leak excessively, and appears to be something you can drop in and run as is, I'd pay $300-$400 for it, providing a 283 is what you want. Since it's coming out of a '57, check the code stamping. If it's the original block, it's worth more than that to a restorer.
  10. stan292
    stan292
    I posted a request on the cl***ifieds here for a 283 at the start of this week. Had a couple responses - $100 for a "rebuilder", $250 for a "runner" that needed freshend up (new rings, etc.), to $400 for a running motor. BTW - the first two came complete with Powerglide trannies - and the guy (Orange54) offered to throw in a spare block.
    I ended up being offered one (and a powerglide) virtually free. It's surprising what shows up when you ask around.
    The point is, like some of the other's said, actual prices depend a lot on condition - and in the case of the old stuff, the possible inclusion of certain "desireable" components.
    One good way to get a handle on prices is to check the HAMB cl***ifeds regularly. All sorts of stuff shows up there, and it usually doesn't take long to find examples of what you're looking for (all cl***ifieds must contain the asking price).
    Good luck -
  11. chopped
    chopped
    Try and figure where he's coming from. If he think it's a gold mine it's one price, if his wife wants the junk out of the garage it's another.
  12. For used engines I use a $1 per cubic inch rule of thumb, unless it's something really collectable.
