How Much Would Cutting The Top Off Of A Car Effect It's Value?
Discussion in 'The Hokey Ass Message Board' started by Slammed88, Jan 19, 2006.
  1. You can go here: http://www.danchuk.com and find EVERYTHING you need to buy to turn any Tri-Five Chevy into a convertable.
    The easiest conversion would be to do a Hard Top...
    The LEAST cost effective conversion would be to do a SEDAN...
    The MOST cost effective one would be to do a four door... but you will have to do A LOT of work.
    They even sell the convertable X member to weld into your frame... the top bows, inner quarter panels... everything. There is a "how to" floating around the net somewhere, and I saw an article in a Chevy Magazine... I'll see if I can't dig that up for you.
    You know how to drill out spot welds, right? Better get that MIG warmed up! :D
    One more thing... Don't cut that car of yours up... please... find a four door or a clapped out 2dr hard top...
    Sam.
  2. fastfreddie
    fastfreddie
    Your car is to nice to cut! If you cut it, someone needs to pop a knot on your head!
    FF
  3. Valentine
    Valentine
    DO NOT CUT ON DOTTED LINE!!! No way in hell. Even if it is rough as **** you can set it up as a drag car!
    Here is a simple equation 55 - roof=Not cool
  4. Oilcan Harry
    Oilcan Harry
    from INDY
    Don't the convertables use the longer hardtop doors? You have the short sedan doors. When the top is off the porportions will be off, unless you use hardtop doors and move the door pillar. If you try this,[ and I hope you're not that dumb] at least don't come back here crying about needing help to fix your F&$*&d up 55. Saw a really clean 57 Chevy in a s**** yard about 25 years ago that someone tried to make a convertable. The sight still haunts me!
