How Not to Woodgrain...
Discussion in 'The Hokey Ass Message Board' started by Django, Aug 22, 2008.
  1. striper
    striper
    Worth persisting with I reckon. Once you get it you'll be the KING.
  2. Excellent post Django.
    Just goes to show that failure is an important part of the learning process.
    If'n ya don't try....
  3. Shifty Shifterton
    Shifty Shifterton
    Somewhere you have a female relative that s****books & crafts. With a way in-depth, over the top, car-nut level of intensity. Find her and have her point you to the woodgraining things she knows about. The tools tend to be small because crafters all use the same kind of organizers with a lot of small compartments. good luck.
    PS your tech made me feel great. Instead of being intimidating, really felt like I could follow along and get the exact results myself. Totally refreshing after all these threads about how to refine iron ore into a GNRS compe***or.
  4. Hot Rods Ta Hell
    Hot Rods Ta Hell
    I'll drink to that!
    Sounds like a good day in the garage, but will I get any work done?
  5. Do what you can by yersef, and then have the Bob Kennedy guy dew the hard ****..Mikey
  6. btbsandman
    btbsandman
    Chillie....you have a great start there. Keep trying and it will work for you.
    Remember only losers buy billet.
  7. Unkl Ian
    Unkl Ian
    What is with the surgical gloves ?
    The ink washes off with water.
  8. Jdee
    Jdee
    We have changed a few things with the kit since I sent that one, if you want to give it another try. The blending from roll to roll is much easier now with the different plate style and Ink. the main reason we have made this change is for the blending, also smear coats make the woodgrain look much better. I think you have the old style roller also, the new ones work better..
    I'll need your mailing address again and I'll send it right out.
    The new inks make a big difference.
    Jdee
  9. Unkl Ian
    Unkl Ian
    IIRC,they also have a smaller diameter roller available for real tight inside corners.
  10. captainjunk#2
    captainjunk#2
    nice glove box door anyhow , just got to practice good luck
  11. chopo
    chopo
    Get a hold of mazdaslam. his partner Dave and himself did some trim work a little while back. It turned out kick *** !! maybe he has some pics?
  12. johnrockin
    johnrockin
    from midwest
    i just had an idea, not sure if it would work. for the waterfall center part, i wonder what it would look like if you split the center. you know like when they would take a piece of wood and split it and then just flip the two pieces next to each other. just a thought....
    kindof a bad example, but you get the point.
  13. Django
    Django
    from Chicago
    Thanks Jdee!!
    How do you roll long distances like the top rail on the '36 dash when the roller isn't big enough to go the distance?
  14. flynbrian48
    flynbrian48
    I did the woodgraining on my '51 Pontiac Tin Woody wagon using foam brushes, small foam rollers with a pattern melted in 'em, and gel wood stain. I also used one of the woodgrain squeege's one finds at all the big box stores and hardware stores. It's super easy, the results are spectacular if I do say so myself, you don't have a pattern that is uniform like the roller kit you have, and it's inexpensive.
    PM or email me @ bcmccool@msn.com if you'd like more info.
  15. Jdee
    Jdee
    I'll try and get some more how to/ pics and videos up soon.
    That roller looks like an old test roller.
    It might be to hard to get into the
    contours. the roller should get into almost any area you need to reach.
    Also you can take the donut off the roller and use it like a stamp, but
    i don't think you need to on that dash.
    i PM'ed ya with some info...
    Jdee
    <object>
    <embed src="http://rbicycle.iserver.net/photos/video/ford/ford.swf" quality="high" bgcolor="#ffffff" name="habit" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" width="320" align="middle" height="270"></object>
  16. Jdee
    Jdee
  17. Jdee
    Jdee
    No pics up zzzzyyy
  18. Unkl Ian
    Unkl Ian
    Pics do not do begin to do justice to the work of JDee and crew.
    Their stuff really needs to be seen in person.
    That is how you get to work on cars that win at Pebble Beach.
  19. Django
    Django
    from Chicago
    That '36 dash looks amazing. Wow.
    One thing going for me and my (lack of) skill level is I have the waterfall trim piece in the middle.
  20. Gotgas
    Gotgas
    from DFW USA
    Django.. you're talented man! Practice will make perfect. You don't even need tools per se. ;)
    Here's my dad's non-HAMB tin woodie that he took a day off to paint. I don't have any good close-ups of the detail. People ask all the time if it's real or a sticker.
  21. 53Chief
    53Chief
    It's the tight spots that get you every time. We hand paint all of our woodgrain projects...let me know if you need some help, we can even match the great job you did on the glove box door.
  22. jamesf
    jamesf
    from hammond in
  23. jamesf
    jamesf
    from hammond in
    Jim Evans dash was done by Cliff McCillopp from the Detroit area. Quite an artist.
