Hot Rods How old are these tires?
Discussion in 'The Hokey Ass Message Board' started by George, Jan 24, 2026.
  1. George
    George
    Looked up how to read the date codes using Google, but this doesn't seem to match up. says DOT U9HF XH3. There's 2 blank spaces after that.
  2. squirrel
    those seem to be batch codes, not date codes. Look for 3 or 4 numbers by themselves, such as 3208 or 248 or something.
    Also pictures of the tires will help, we might be able to guess what decade they are from, just by how they look. I don't know if you've looked at modern tires, they look pretty fancy compared to old ones (unless they are repops or something).
    lothiandon1940 likes this.
  3. fastcar1953
    fastcar1953
  4. fastcar1953
    fastcar1953
    This is for modern tires. ^^^^^^
    abe lugo and lothiandon1940 like this.
  5. tubman
    tubman
    Tires made before 2000 have a 3 digit date code. I think it's the week number followed by the last digit of the year. It really doesn't matter because they are already waaaaay too old. Tires made after 2000 have a four digit date code WWYY (35th week of 2011 in the example above).
    Johnny Gee and twenty8 like this.
  6. BigRRR
    BigRRR
    You may want to look at both sidewalls - I have found on many tires the DOT # on one side lacks the date code, but the other side will have it!
  7. squirrel
    usually on the "back" of the tire....
    lothiandon1940, warbird1 and BigRRR like this.
  8. George
    George
    And there's the answer! Had them on white wall in. My avatar cars has 2013s and my O/T one is 2016s....
    winduptoy and lothiandon1940 like this.
  9. squirrel
    2013 tires are getting a bit old for my taste..but then so are 2016...
  10. fastcar1953
    fastcar1953
    5 to 7 years is my limit. Doesn't matter what they look like.
  11. Beanscoot
    Beanscoot
    Ha! Three of four on my old pickup are date coded 1989.
    So there!
    Mel58 and leon bee like this.
  12. tubman
    tubman
    How do yo know that? The three digit date codes (pre 2000) carry only the units digit of the year. They could be 1989, 1999, 1979, 1969.....
  13. lothiandon1940
    lothiandon1940
    ......Keep it under 100mph!!!!:eek::D
  14. twenty8
    twenty8
    It's all good.......... 'til it's not.
    winduptoy likes this.
  15. leon bee
    leon bee
    I have a car sitting on Coker bias plys for about 15 years now, still seem kinda new to me.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    bias plies last longer than radials do. The rubber loses its ability to hang onto the steel belts in radials after about 6 years causing them to fly apart at speed. Bias plies have no steel belts so they do not suffer from that problem
  17. twenty8
    twenty8
    The rubber compound does harden over time though. This will affect sidewall flexibility and the ability of the tread to grip the road surface. The problem will be more noticable in wet or icy conditions and in emergency braking/steering situations. Common sense should still be exercised when it comes to bias ply tire age.
  18. blue 49
    blue 49
    from Iowa
    I was thinking that there used to be a code that the dealer recorded, and was used to determine how much excise tax had to be paid.
    Gary
  19. I once had to use a 25 year old bias ply tire to get home after having a blowout at my uncle's way out in the sticks. I swear despite the tire being dead on recommended pressure it felt like I was driving on a flat tire lol
