How polluted is your car's gene pool?
Discussion in 'The Hokey Ass Message Board' started by extremist, Mar 12, 2007.
  1. BadgeZ28
    BadgeZ28
    from Oregon
    1941 Willys coupe plastic body
    S-10 frame
    Mopar 360 V8
    Mopar 727 trans.
    VW license plate light assembly
    1958 ford grill
  2. 55 Buick Special.
    Ls 5.3
    4l80
    88 cavalier rack&pinion
    Early bronco 9"
    Front disc 70s Buick
    Rear disc 2014 mustang
    Astrovan hydroboost
    Truckarm rear suspension
    More to come I'm sure.
  3. gene-koning
    gene-koning
    48 Plymouth body shell.
    90 Dodge Dakota
    70s Mopar driveshaft
    80s Chrysler 5th Ave rear wheels
    I have a 47 Dodge pickup next in line, the list on that will be pretty short as well. Gene
  4. Door skins, 1/2 of cab roof, nose cone and grille shell from 47 Autocar U-70
    Complete custom cab frame made from steel tubing. (original wood frame made great campfire)
    Anything in picture that is self-etching green is tin bashed at home
    Engine is 1980 Detroit Diesel 6v53 2 cycle
    Trans is Allison 2400 from 07 F-650
    Axles(3) from 97 Dodge 1 ton dually on home engineered air ride suspension.
    3X9 C channel frame from a Continental fire truck (IH S series chassis)
    Front fenders: 42 Studebaker president rears
    Home made 10' wrecker body, no boom (not made yet)
  5. gimpyshotrods
    gimpyshotrods
    1960 Ford Falcon shell.
    Factory original radiator (yeah, for real).
    Aftermarket upper and lower front control arms.
    Aftermarket anti-sway bar.
    560in.-lb. springs.
    Nissan rotors.
    Chevy Caviler calipers.
    Geo Metro power brake booster.
    Corvette master cylinder.
    1966 Ford Mustang 200 block.
    1982 Ford Fairmont cylinder head, carburetor mount milled off, custom spacer adapter in place.
    1992 Chevrolet S10 4.3l V6 throttle body fuel injection, with custom ECM, including spark control.
    7-pin HEI distributor with no advance mechanisims whatsoever.
    4G Ford 200A alternator.
    Sanden 508 air compressor.
    Hella horn and headlights.
    Mustang floor brace to clear alternative transmission.
    1994 Chevrolet Camaro LT1 T56 6-speed transmission, with LS1 input shaft.
    1963 Ford Econoline bellhousing.
    1994 Mercedes 190E complete clutch(except it is a SPEC Stage II Kevlar one).
    Flywheel machined to Mercedes specification.
    Custom extended pilot bushing.
    Modified McLeod adapter. Dummy input bearing collar turned down to accept stock throwout bearing carrier.
    Mercedes throwout bearing on Falcon input bearing collar (yeah, it fit, and like it was supposed to be there).
    Modified z-bar, to correct for fork position, correct pedal ratio, and to clear steering.
    Saginaw integrated box power steering.
    Core shifter, genuine Hurst stick.
    1991 Ford Ranger 8.8 rear axle, re-drilled to 4-lug ('cause I CAN).
    5.13:1 rear gears, Detroit TruTrac torque biasing limited slip.
    Custom rate, lowered, 6-leaf rear springs.
    Pannasport replica roadracing wheels.
    Jaguar fuel filler cap.
    1970 Mustang fuel tank.
    1993 Jeep Cherokee 2-door front seats.
    1960 Thunderbird console (sitting on a tunnel handmade to hold it).
    Retrosound stereo head, four Infinity 6-1/2" round drivers, one 15" subwoofer, 1600watts total in amps.
    Vintage Air air conditioning.
    Fully braced subframe.
    SCCA stickers for the quarter windows.
    Probably forgot to list more than I listed.
    Still looks like I pulled it out from behind a barn.
  6. HUSSEY
    HUSSEY
    Only because you asked...
    1949 Chevy 1 Ton Cab and Front Clip
    1947-1953 Chevy Bed and Rear Fenders
    1947-1954 GMC Tailgate
    1991 Chevy S10 Regular Cab Long Bed Chassis
    2000 S10 Blazer Belletech Front Drop Spindles
    2000 S10 Blazer Seal Front Wheel Bearings
    2000 Blazer Dual Piston Front Brake Calipers and Large Diameter Rotors
    1980 Corvette Brake Master Cylinder
    S10 ZQ8 Front Sway Bar
    2000 Oldsmobile Bravada 3:73 Limited Slip Rear End
    2000 Oldsmobile Blazer Rear Sway Bar
    1991 Chevy C1500 350 CID w/ TBI Fuel Injection
    1990 S10 700R4 Four Speed Overdrive Automatic Transmission
    1990 Chevy Throttle Body Injection (TBI) Fuel Injection System
    1960’s Chevelle Split Back Bench Seat
    And a few key aftermarket parts...
    Dual Diaphragm 8 in. Vacuum Brake Booster
    Fuel Injection Connection TBI Stand Alone Fuel Injection Wiring Harness
    Headman S10 V8 Conversion Headers
    Custom Fabricated Mandrel Bent Exhaust
    Flowmaster 40 Series Delta Flow Muffler
    Summit Racing 22Wx19Hx3 in. Two Row Radiator w/ Internal Transmission Cooler
    Spal 1,300 CFM Electric Fan
    Painless Performance 21 Circuit Chassis Wiring Harness
    New Vintage Speedometer and Quad Gauge Set
    Bosch-Actron Retro Reproduction Sun RC-85 Tachometer
    Lokar 23 in. Nostalgia Transmission Shifter
    Ididit 30 in. Tilt Column
    Moon California Metal Flake 15 in. Steering Wheel
    Moon Gas and Brake Cast Aluminum Pedals (For faster acceleration and harder braking.)
    American Racing Torq Thrust II Wheels, 18x8 in.
    Bridgestone Potenza 245/40R-18 Tires
    Custom Autosound Retro Radio
    Rockford Fosgate Prime 3-way 6x9 in. Speakers
    Hella Horns
    All fabrication by your truly.
  7. Legendlives
    Legendlives
    38 (English) Ford body
    Mustang quad-cam engine
    Mustang manual gearbox
    Jaguar IRS and drive shaft
    Mazda steering column
    Mazda pedals
    Lada steering box
    Ford Escort handbrake lever
    GMC Supercharger
    and a lot of swapmeet parts with unknown heritage!
  8. CowboyTed
    CowboyTed
    '58 Austin
    Jaguar suspension front and rear, along with brakes and steering.
    Chevy engine and tranny, Jag driveshaft and rear end.
    Honda seats
    A whole bunch of recycled Jag and Ford sheetmetal for rust repairs.
    Mines not nearly the mongrel some of you built!
  9. mgtstumpy
    mgtstumpy
    35 Chebby
    • OEM body with jewellery (Windscreen posts [repop frame], head & tail lamps, bars & top irons), boxed OEM 1934 frame with new cross members
    • 1986 GM engine and auto transmission, 1965 GM front suspension, 1974 GM steering rack with 1971 GM steering column and Mooneyes Banjo steering wheel
    • 1980 GM brake booster with 1970 Ford master cylinder
    • 1966 Jaguar rear suspension
    • 1970s Cragar SS wheels
    • Hidden 2000s Sony stereo
    46 Olds
    • OEM frame with new cross members, 1990 GM suspension (Air), engine and auto transmission :eek::eek:
    • Underdash 1990 GM master cylinder with hydroboost :eek::eek:
    • 1960s Edelbrock X1 with OT hidden 6x2 EFI :eek::eek:
    • OEM seats with repop OEM 1946 trim and new wood graining
    • OEM hydra-matic column with pearled OEM steering wheel
    • OEM 1946 2 tone paint scheme, new chrome & NOS badges etc
    • OEM dash with modern 2000s movements
    • AC, PW & PS :eek::eek:
    • Custom auto sound radio
    • 2000s painted steel wheels with NOS hubcaps
    Had to add 3pt seat belts (Colour coded) to get registered down here and all new safety glass.
  10. Hmmmmm...mine is a 34 ford.
    top filler is 61 corvair coupe
    quarters and decklid are after market steel
    wheels are 55 chrysler
    Pontiac grand am seats
    engine is 57 Pontiac
    trans is 67 firebird
    rear is winters
    aftermarket driveshaft
    Walker radiator Vega steering box
    Dash is 34 chev
    hood sides are 34 chev
    turn signal indicator is 53 buick
    steering wheel is 40 buick with aftermarket rim
    pedals are 49 ford F-1
    brakes are 68 Merc rear
    mustang disc fronts
    40 chev taillights
    blc 903J headlights [40s cab over truck]
    model A ford rear spring
    aftermarket front spring
    32 ford heavy front axle
    Frame is 33 ford coupe
    park brake is 32 ford
    40 ford steering column/switch/steering lock
    33 ford hood tops and grille shell
  11. bobbytnm
    bobbytnm
    My old truck is a bit of a morphodite also and I tend to find parts that will work from whatever source is at hand. Here are a few of the main components that I can remember;
    1949 Ford F1 truck
    500ci Caddy engine/TH400 trans
    1960 Ford 9"
    1982 Ford truck rotors
    GM "A" body outer bearings
    Cadillac brake calipers
    Ford Focus brake booster
    Cadillac master cylinder
    Oldsmobile proportioning valve and brake lines
    82 Toyota power steering box
    1975 Dodge D200 radiator
    Packard air cleaner
    1990 GMC van gauge cluster
    1963 Pontiac rear seat speaker grill (on dash)
    1964 Mercury front fender trim pieces
    2000 GMC truck bed floor and front panel
    1958 Packard dash knobs
    1970 Thunderbird headlight switch pod
    1964 Buick steering column & wheel
    1964 Oldsmobile ignition switch
    late 70's Ford truck slotted mags
    Various trim pieces from early 60's Fords
    Bobby
  12. 1954 CHEVY
    76 CAMARO SUB
    88 CAMARO DIFF
    95 CORVETTE STEER COL.
    JEEP CLUTCH PEDAL/BRAKE
    CAMARO 5 SPEED
    PONTIAC FIERO BUCKET SEAT
    1966 230 CID CHEVY BREAD TRUCK
    1966 1MPALA STEER WHEEL
    CORVETTE E BRAKE HANDLE
    74 CHEVY TRUCK RADIATOR
  13. drtrcrV-8
    drtrcrV-8
    '28 AA Ford truck frame & roadster body(& radiator) '29 roadster top '34 BB ford truck front & rear axles(& wheels) '56 Ford F-1 steering '99-up Ford f-350 disc brakes(all 4 corners) '67 ford master cyl 224 Mercruiser engine Toyota waterpump Small block Ford dampner '90's(?) VW alternator Chev Lakewood bellhousing modified to use '28 AA pedals Isuzu T-5Trans. Astro-Van seat late '30's ford tailgate(modified) Fabricated long/wide PU bed w/dually fenders '34 ford headlights...... Mixed enough?? Almost forgot :Rustolem Gloss Black(still in the can; not ready yet. LOL) NO, it's NOT dropped ; it's a Working "survivor" Truck.
  14. Torkwrench
    Torkwrench
    1959 GMC longbed stepside.
    Pontiac 326 engine, out of a 1967 LeMans.
    M-20 Muncie 4 speed from a 65 Impala.
    1959 Pontiac 3:42 Posi rear axel'
    1959 Chevy passenger car rear brake backing plates, drums, etc.
    1960 BelAir steering wheel.
    1952 Chevy parking lights.
    The taillights are a combination of 1953 Buick, 1960 BelAir, stock GMC buckets, and Ace hardware sink drains.
    1959 Chevy 60 series grain truck radiator.
    1955 Chevy pickup rear bumper.
  15. Mr48chev
    I'd have to sand it down to find the gold lacquer paint to make sure but I think the left front fender is the only original part left of the truck as it was when I bought it in March 1973. Everything else has been changed or is getting changed this time around .
    This go the frame is out of a long bed half ton GMC as I am stretching the wheelbase but want to keep a 1/2 ton frame.
    Front suspension is going to be industrial chassis crossmember and Dodge Dakota pieces. Rear most ;likely will be a nine inch Ford with the rear springs off the Dakota as the Dakota has a tiny rear axle.
    Engine 68 Chev 292, Trans is the AX 15 trans out of the Dakota with a Novak adaper. I haven't checked the width of the seat but the Dakota may donate that too. 200 worth of donor truck going a long ways.
    Stretched cab is a mix match of cabs I have collected over the years, Bed has been on the truck before but isn't the beat up one it originally came with in 1973.
    Steering wheel is out of a 53 Belair Air, Dash is the original one that was in my 51 Merc coupe that I bought when I was 16 with a gauge change and hidden sound system. Steel wheels with either 55 Packard Clipper or 57 Buick hubcaps depending on how I feel that day.
  16. these laundry lists are simply amazing !
  17. junkyardjeff
    junkyardjeff
    I do not know if I would say my 55 sunliner has a polluted gene pool since its all Ford but different years but my 37 Chevy has a Ford 8 inch and 70s F150 master cylinder and maybe a Ford Y block.
  18. tfeverfred
    tfeverfred
    Mine? The bastard daughter of a 100 scoundrels.
    whtbaron likes this.
  19. seb fontana
    seb fontana
    from ct
    HA HA HA HA HA HA...........
  20. Original bodied 32 ford roadster.
    46 ford flathead
    40 ford transmission
    40 ford brakes
    40 ford column shift
    40 ford steering wheel
    40 mercury 15" wheels
    41 Chevrolet TAIL LIGHTS :D:D:D
  21. Calcrenshaw
    Calcrenshaw
    55 chevy ford rear end and drive shaft everything else not chevy is either harware store or handmade by me
  22. Body:............'28 Ford
    Frame:..........'32 Ford
    Front axle:....'34 Ford
    Spindles:........'40 Ford
    Trans:.............'92 Chevy C-10 pickup
    Rearend:.........'79 Ford F-150 pickup
    Roof:..............'86 Toyota minivan
    Engine:...........'58 Chrysler Hemi
    Sway bar:........Volvo 240
    Radiator:.........Mustang?
    Seats:..............Austin Healey
    Steering:.........Chevy Vega
    '36 Willys body
    '53 331 (354) Chrysler hemi
    '54 Willys Hydramatic (the good one - Dual Range converted to Hydro Stick)
    '56 narrowed Olds rear end
    '63 Buick rear brakes
    '72 Torino front disk brakes
    ? junk yard import bucket seats
    Corvair steering gear
    Drag Machine tranny adaptor
    '59 Chevy pickup fluid coupling
    ? junk yard import gas tank
    '54 Buick tail lights
    Mustang II shifter
    '80s Chrysler alternator
    '30s Arvin accessory heater
    Holley 3bbl carb
    Industrial 4" stainless centrifugal water pump
    VW rear view mirror
    Rest is home made. Wife calls me 'Bracket Man"
    Just Gary likes this.
  24. Hmmm...
    1951 Ford
    1950 Ford fenders and doors
    1949 Ford bumpers
    1949 Ford tail lights (x2... extra set grafted in)
    1949 and 1951 Ford trunklids, lengthened 8" and grafted together
    1956 Oldsmobile headlight buckets (hand-modified fenders to fit)
    1955 Dodge grille
    1959 Edsel dashboard
    1965 Thunderbird seats front and rear
    1965 Thunderbird interior door handles
    1964 Comet console
    1965 Mustang gas tank
    1960 Plymouth steering wheel
    1955 Oldsmobile hubcaps (sometimes)
    Mostly Ford. Probably forgetting something or other. Still in progress.
  25. Raiman1959
    Raiman1959
    My daily ''beater'' I drive....bucket roadster:
    *1914 Olds body, windshield and wood dash (was my grandpa's...sat in barn since 1932 till 2012)
    *canvas top from 65' Triumph Spitfire....cut and sewn to fit by my wife....nice job;)
    *1947 Hudson rearend
    *1957 Willys Super-Hurricane 226 6 cyl.
    * 1919 Ford frame, boxed and 'adjusted' to fit
    *radiator from 66' Bronco
    *Radiator shell is 1927 Hupmobile (tried to find a 1914 Olds....it ain't out there!)
    *1958 Willy's Wagon Transmission 3 speed
    *seat is from 1960 willys jeep backseat
    *1960 Impala steering wheel, with gauge cluster from 1948 Ford
    *wheels from 61' Ford Galaxie
    *hubcaps from 1959 Studebaker
    *gas tank from 1957 Triumph TR3
    _________and the 2 doors were made from vintage wood brackets of an old 1930's wooden chest...while the door skin panels were from an early 50's metal filing cabinet :D
    A mish-mash of parts...but, it turned out better than expected...no complaints at normal speeds! 002.jpg
  26. 1940 Ford coupe
    '39 rear fenders with braces made from the wiper linkage of a Freightliner fire engine
    '38 sedan seat
    '68 Dodge 1/2 ton front springs...on the rear
    '68 Nova steering box
    C/J Jeep pitman arm
    '66 Corvair steering column
    '63 Dodge brake pedal and mount with a Mustang master cylinder...all under the dash
    '68 426 Dodge industrial long block from a Chris Craft boat
    '63 Max Wedge intake and '64 carbs
    '65 Imperial push-button trans with a button shifter assy. made from three different cars
    '69 Dart driveshaft
    '67 GTX rear
    '74 Dodge pick up gas pedal assy.
    Main hoop of the roll bar is from a paddy wagon divider
    '64 Mustang carpet set
    '41? Chrysler inside door handles and window cranks
    '56 Ford Big Job truck hood scoop...whenever I get the hood on
    And a pretty good selection of home made mounts, brackets, floor pans and etc.
    This is all from memory...so some of the years may be + or - one
  27. Ron Brown
    Ron Brown
    Purebred....
    original body, all panels,
    Engine
    tranny
    rearend
    oh, forgot, aftermarket dropped axle. semi purebred
  28. 327Eric
    327Eric
    27 cars contributed to the delinquency of my 55 studebaker president, which now looks like a 54 champion, with a 327 and a 4 speed.
  29. spanners
    spanners
    'And a partridge in a pear tree'.
    seb fontana likes this.
