Technical How Strong are trailer rims?
Discussion in 'The Hokey Ass Message Board' started by Modelafish, Nov 27, 2024.
  1. Modelafish
    Modelafish
    So I've had chrome smoothies on my Model A for a few decades, but I've never been happy with the way the rims stuck out from the fenders, due to the width of the rear axle I found to use under it. Changing the rear axle out (and all the suspension components) isn't in a social security budget. So I found and polished a couple Ranger 8 hole aluminum rims that have about an inch and a half better offset; plus going from 275/60R15 to 255/70R15 will get me another half inch. The issue is getting front rims to match. I found a pair of aluminum 10 hole trailer rims that are close in appearance for $150 on Amazon. They say they're rated for 2200# each, and my whole car weighs 2500. Anyone have any experience using these on the front? It has a 4" drop tube axle with 67 T-bird disc brakes. https://www.ecustomrim.com/products...x6-15-x-6-5-lug-4-5-center-modular-design-rim
    trulyvintage likes this.
  2. Ewwwwww
    Sorry
    But there’s better wheels out there
  3. You have to make sure that the width
    of the trailer rim is adequate for
    the width of the tire that you are
    putting on it - I would check with
    a local tire shop that you trust
    or whoever will be doing the
    mounting balancing.
    Jim
    Transporting To Travel
    Traveling To Share
    Stories From The Road
    alanp561 likes this.
  4. Modelafish
    Modelafish
    They're 6" wide, same as I have on the car now.
    Bill's Auto Works likes this.
  5. 15x6 steel wheels are $90-130 new
  6. CME1
    CME1
    Do not use trailer wheels, they are not designed for automobile use.
  7. Modelafish
    Modelafish
    I have steel wheels now. I'm looking for aluminum to match the rears.
  8. Modelafish
    Modelafish
  9. Modelafish
    Modelafish
    What's the difference though? They're both round, have 5 bolt holes, and hold air. I can see the difference with tires.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A Cragar SS wheel of the same size and application is rated at 1580 lbs. You take it from here.
  11. twenty8
    twenty8
    I don't agree with this at all. Trailer wheels will have a higher load rating than car wheels and will be ok to run.
    Tires is a different thing all together. Trailer tires have a much stiffer sidewall and will give a harsh ride. They are also usually designed to be pulled in a straight line and are not really suited for the steering/braking job on the front of a car.
  12. KenC
    KenC
    Trailer wheels are plenty strong, IMO. Take a look at a loaded tandem trailer turning on pavement. Lots of side load, dragging the tire along rather than rolling as it would on a steered spindle. Bad enough with trailer tires, which have a slight crown on the tread. Now guys like me use auto/truck tires with a nice wide sticky tread. That really loads the wheel in a turn. Now, concentric rim/tire mounting surface/lug bolt circle etc may not be held to auto tolerances but strength shouldn't be an issue. Again, IMHO.
  13. tubman
    tubman
    I have to agree with the last two posters. If you can live with the appearance, I don't see any reason not to use them.
  14. Modelafish
    Modelafish
    This is the rim. I can get two for $150 w/ free shipping from Amazon.
  15. twenty8
    twenty8
    What is the load rating ???
  16. Mike VV
    Mike VV
    from SoCal
    Are you talking about just the "rim", or the whole "wheel" ?
    Mike
  17. Modelafish
    Modelafish
    2200 lbs each.
  18. Modelafish
    Modelafish
    The rim only, and I'll mount my existing automotive tire on it. No "trailer tires" involved.
    duecesteve likes this.
  19. twenty8
    twenty8
    I'm guessing your Model A is not 8800 lbs, so you will be fine.........:D
    Johnny Gee and arse_sidewards like this.
  20. twenty8
    twenty8
    Yes, I know what you are saying is correct, but do we really have to ??? It won't help this thread.;)
  21. Matt Dudley
    Matt Dudley
    from New York
    An aluminum trailer wheel will probably be fine. A wagon type steel trailer wheel is cheap junk these days. You may find issues with balance and runout though. They are not built to the same QC standards knowing people don’t ride on trailers generally
  22. arse_sidewards
    arse_sidewards
    from Central MA
    There was an old thread on pirate4x4 about this. The consensus was that they're as strong or stronger than any equivalent automotive rim at the expense of weight and fit and finish.
    big john d likes this.
  23. LOL! Thank you, Mike.
    Ben
    Fortunateson likes this.
  24. 19Fordy
    19Fordy
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not an issue. It’s lawyer talk. There’s 1000’s of car’s running around with p***enger car wheels with offsets that differ from factory specs.
  26. tubman
    tubman
    Like I said, "If you can live with the appearance....".:rolleyes:
    Clydesdale likes this.
  27. Clydesdale
    Clydesdale
    Maybe he can fit some wheel covers....maybe.....please......please fit wheel covers!!! :eek:
  28. oldiron 440
    oldiron 440
    Trailer wheels are designed for higher side loads and higher load carrying capacity things that are capable of destroying automotive wheels. As far as using wheels with a 2200 lbs weight limit on a vehicle that has a weight of about 2200lbs I’d say it’s a little overkill but it should work out well.
    2OLD2FAST, 5window and arse_sidewards like this.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    I don't think the OP ever asked for an opinion on the style of the wheels , only if they were deemed usable .
