Technical How the Hell do these come apart?!
Discussion in 'Traditional Hot Rods' started by Lucky77, Nov 12, 2013.
  1. Lucky77
    Lucky77
    The front spring perches on my 1950 F1 have me baffled. How does the leaf spring come out so I can get to the rivets to remove the perches. ImageUploadedByH.A.M.B.1384307278.701242.jpg
  2. manyolcars
    manyolcars
    wow. first you gotta clean that 'stuff' off so you can see the fasteners
  3. Might help to take a wire brush to all that dirt & old grease first so you can see what you're dealing with ? Just a thought. I'm guessing you may have to remove the grease fitting and use some sort of puller in the hole but there will be someone along shortly who has the answers. I'm just amazed that you didn't even bother to clean up the crap and have a look at it for yourself before posting. Most of these type of things are pretty obvious once you have a good look at how they go together.
  4. telecustom
    telecustom
    from Langey, BC
    was there a bolt on the end of it...??
  5. Lucky77
    Lucky77
    Thanks for stating the obvious and guessing NHBandit.
    I scraped at it enough to see there's just a grease zerk on the end of the perch. Just need to know if I need a puller or something else to get this spring out. ImageUploadedByH.A.M.B.1384308565.708545.jpg
  6. HOTRODPRIMER
    HOTRODPRIMER
    It's like the old adage "You can see the forest for the trees" in this case the "Bolt for all the dried dirt". :D HRP
  7. willys1
    willys1
    from South Ga
    Looks like you need a spanner wrench or socket On a gm , that pin is threaded and screws in or out .
  8. specialty tool or just a screw driver in one of the notches and a hammer and tap it around counter clockwise. (might soak the be-jesus out of it first with your fav. solvent)then drive the pin out
  9. low budget
    low budget
    from Central Ky
    Not sure if your gonna need that out anyway or not but I beleive I could get to those rivet heads with a 4 inch grinder.
    If youve got the spring loose at the back hanger just raise or lower it enough to get at it.
    After you get the heads ground off you can hit the hanger downward enough with a sledge to break it loose and get it off.
  10. manyolcars
    manyolcars
    That really looks like REAR spring
  11. Lucky77
    Lucky77
    FRONT of the REAR perches.
    Thanks for all the help...
  12. tb33anda3rd
    tb33anda3rd
    if you clean off the inside edge near the frame i believe you will find a lock bolt that keeps the pin in place. once you remove it you can drive the pin out through the hole on the inside of the frame.
  13. Lucky77
    Lucky77
    Thank you, that's what I was looking for.
  14. FrozenMerc
    FrozenMerc
    WINNER WINNER CHICKEN DINNER!!!
    All you rubes who were just guessing would have ruined alot of screw drivers and chisels thinking that you could unscrew the spring bolt. Below is a picture of a new pin and the notch at the back of it is were the retaining bolt engages it. More then likely, you will still need a BFH and big bowl of Wheaties to drive the damn pins out once the retaining bolt is removed.
  15. beernut
    beernut
    from solvang
    air hammer and lots of spray lube :cool::cool::cool:
  16. saltflats
    saltflats
    from Missouri
    There will be a cross bolt like a king pin wedge lock bolt take the not off and tap it out then you can use a bolt and sleeve in the end where it is threded to pull it out.
    If the pin has a bad groove wore in it you will have to fiddle with it to get it lined up to get it out.
  17. Somebody
    Somebody
    Cut the rivets and shackle bolts off and re-build it all with new grade 8 fasteners.
  18. schuyler
    schuyler
    from Tennessee
    Definitely a lock pin back there. Also, I would ask questions about your f-1 at the fte website...more info and almost never anybody that's rude.
  19. Hotrodbuilderny
    Hotrodbuilderny
    I believe it's you can't see the forest for the trees.
  20. propwash
    propwash
    from Las Vegas
    Nobody's ever rude? How much fun could THAT be?
