how tight should spindle be?
Discussion in 'The Hokey Ass Message Board' started by gasserdan, Aug 9, 2013.
  1. gasserdan
    gasserdan
    I just had my front axle chromed. I filed down the axle and got the spindle on and king pin installed. Now I am not sure how tight the back and forth motion of the spindle should be? Its a little snug, I don't know if I should file a little more off or not?Any ideas would be appreciated. Thanks,Dan
  2. Dreddybear
    Dreddybear
    The king pin stays put in the axle, so it being chromed should have no influence on the spindle being tight.
  3. Dreddybear
    Dreddybear
    Were the bushings reamed to fit the king pin? They would have had to be.. they are what determines how tight it is..
  4. Hnstray
    Hnstray
    from Quincy, IL
    Not necessarily. It also depends on the depth of the axle king pin boss vs the inside dimension of the spindle with the thrust bearing in place.
    Chroming the axle could build up the pin boss on the axle, thereby reducing clearance.
    The resistance being felt may not be from the king pin/bushing fit.
    Ray
  5. Dreddybear
    Dreddybear
    I guess I'm just referencing my own experience with it. Aren't there thin shims that come with the bearing?
  6. black 62
    black 62
    from arkansas
    should flop easily...
  7. gasserdan
    gasserdan
    apparently I did not make myself very clear. When my front axle was chromed there was a thin layer of chrome on top and bottom of the axle where the kingpin goes through. It was so tight I had to file off some of the top and bottom to have enough clearance for the spindle and bearing. I could file down more if I needed too I just did not know how easily it should hove back and forth with out a tire and wheel on it. Thanks, Dan
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    One finger on the end of the spindle should move it easily with properly fitted kingpins.
  9. Dreddybear
    Dreddybear
    Ah, I get it. Like he ^ said it should move easily with a finger. :)
