I bought one here cheap to do visor. http://www.irvansmith.com/scart/punches-hole-flares-c-3_54_55.html
I use an old Greenlee manual electrical knock out set and flip the cutting die. If dimpling a 1" hole I use the 1 1/2" top and an inverted 1 1/4" cutter and just crank till its where you want it. Low tech, cheap and easy to use in tight spaces.Clear as mud?
I dun maded my ownses The only problem I have with the "Storebought" ones is they are made on even 1" 1.5" 2" etc.. sizes. I made mine to fit Greenlee KOs, as The KOs are easy to find, and much nicer to use than a holesaw when you need to make a bunch of holes, this is a bed floor for an OT project, actually it is for my 99 Dodge Ram 2500 that is my tow rig: I also bored/threaded the center of my dies, so I could use a Greenlee Hydrulic KO punch, as it allows me to do dimples in the center of large panels that my press would not allow. They also make nice drink holders:
I have found that 30 degrees is nice angle for the dimple, with the OD of the dimple 1.5 x the diameter of the hole makes the most visually pleasing dimples.
This is my die before I did the center hole: The male die is 2 pieces, welded together, just because I had some 6" rounds laying around that were 1" thick, and they were free, + it made for less machining.
I've had good luck with my dies from Irvan Smith. I've even punched .125 chrome moly sheet no problem. I used to make my own out of aluminum but they lost there edge to quick. The ones I have from Irvan Smith are heat treated. Very resonably priced to
