how to converte a 6 volt system to a 12volt system
Discussion in 'The Hokey Ass Message Board' started by classiccarman, May 21, 2013.
  1. classiccarman
    classiccarman
    what all do I have to change to get a 6 volt system for a 12 volt system?
  2. Russco
    Russco
    from Central IL
    If you do a search its all been covered pretty well.
  3. The first thing you need to do is tell what type of car you are working on!!
    Charlie Stephens
  4. oldolds
    oldolds
    Put in a 12 volt battery. Replace everything that burns up. :D
  5. d2_willys
    d2_willys
    from Kansas
    This subject is well do***ented on this site. Look under technical and do a search. Thank you and good luck!
  6. d2_willys
    d2_willys
    from Kansas
    Don't forget to put the + to ground, LOL!:eek:
  7. Rusty O'Toole
    Rusty O'Toole
    I have changed a few but I wouldn't do it again. 6V worked for 100 years and will work for you too. It is easier and cheaper to fix what is wrong, rather than replace half the electrical system then still have to fix what was wrong.
  8. Russco
    Russco
    from Central IL
    I guess it must depend on the car then. I've done a few and they were not that bad to do. Thats about the first thing I do to them anymore. Although I usually put a new entire harness in while I'm at it.
  9. mustang6147
    mustang6147
    from Kent, Ohio
    A couple budies did theres, it was pretty simple....
    Put a 12 v battery in, put a pretolite alternator in, switched all bulbs to 12 volt, switch brake switch as well. and your off....
    Starter was never changed, and was still good 10 yrs later....
    What annoys me about 6 volt, is the slow crank of the engine. It seems right when it isn't gonna start, it starts. That's dries me up a wall
  10. ^^^^^^^Why change the brake switch? They're neither 6 or 12 volt and, if they were, a 6 volt would last forever with 12 volts running through it.
  11. Russco
    Russco
    from Central IL
    I change the alt, battery, coil, all the bulbs, add runtz voltage regulators to the gauges. and skip the ameter in favor of a voltmeter. And I think thats it, I may be forgetting something but that will get you started. I usually change out the complete wiring harness too they are always old and questionalble anyway.
  12. RussK
    RussK
    from Atlanta Ga
    I wouldn't use a runtz , I hear when the die they can send the full voltage 12 v to your gages.
    I'm doing mine and from what I researched the best way to go is to use a ford instrument cluster voltage regulator, they were used to the 70s and are still easy to fine.
    I got mine from rockauto for 39.00 bucks but may find one cheaper
    STANDARD MOTOR PRODUCTS Part # VRC604
