How to cut & sew carpet?
Discussion in 'The Hokey Ass Message Board' started by 56KUSTOM, Feb 27, 2011.
  1. 56KUSTOM
    56KUSTOM
    I've installed ready made sets but I've gotta be able to make them fit better then the ACC one in my '56!
  2. stanlow69
    stanlow69
    Start with a piece of paper. Figure out where you want to cut it to fit your floorboards so it will lay smoothly. When you are satisfied. Lay the padding in the car and cut it the same way. Lay the carpet in your car and do the samething. You will have to sew the carpet together where you cut it or you will have to bind it, or both.
  3. 56KUSTOM
    56KUSTOM
    Thanks!Anyone else?
  4. K13
    K13
  5. 56KUSTOM
    56KUSTOM
    How about fitting over the hump?
  6. Pir8Darryl
    Pir8Darryl
    As stated, use paper to make a template. cut the carpet slightly oversized, trim to a perfect fit.
    I've only seen it done when a neighbor was doing it, but it looked pretty straightforward. He sewed it all together with dental floss. Said it was cheaper and stronger than commercial carpet thread.
  7. brigrat
    brigrat
    from Wa.St.
    I have used a curved carpet needels and whatever shade/strength fishing line desired!
  8. K13
    K13
  9. junkyardjeff
    junkyardjeff
    I could show you better then I could describe the procedure.
  10. jackiemach
    jackiemach
    from New York
    I have used the carpet service for it.
  11. 1971BB427
    1971BB427
    from Oregon
    Did mine from butcher paper template I built. Then sewed it on the back side with carpet thread by hand. I sealed the seam on the back side with black RTV, and it worked great! I have no carpeting experience, so just did what I thought would work, and it did!
    Grand total for carpet, thread, needles, etc. was under $40.
  12. falconsprint63
    falconsprint63
    from Mayberry
    dependng on the carpet a steamer like the cheapies you buy for steaming your shirts or whatever works well for shaping to odd spaces too.
  13. 56KUSTOM
    56KUSTOM
    Nice!
  14. logride
    logride
    from CB IA
    I have seen Stanlow69 in action and would take his advise.
