Technical How to distinguish Laquer from Enamel?
Discussion in 'The Hokey Ass Message Board' started by GTfastbacker, Dec 23, 2021.
  1. Hi Guys,
    is there a trick to distinguish enamel from lacquer? Can i try certain solvents?
    Thank you
    Joe
  2. Budget36
    Budget36
    Not sure, but you must really be in the Xmas spirit! ;)
  3. Jimbo17
    Jimbo17
    Maybe look for Orange peel in the paint!
    Jimbo
    GTfastbacker likes this.
  4. Put a little lacquer thinner on a rag,and rub the paint where it wont show like a lower wheel well.If you get color on the rag its lacquer.
  5. ^^^^^
    That is my method.
  6. COCONUTS
    COCONUTS
    Someone once told me that lacquer is smooth and soft while enamel is hard and not as smooth.
    GTfastbacker and hrm2k like this.
  7. hrm2k
    hrm2k
    My 1964 Caddy is factory lacquer except the right rear quarter. The break point is the back edge of the door. The factory lacquer is so smooth to the touch. The rear quarter is not as smooth and harder to the touch.
    GTfastbacker and COCONUTS like this.
  8. pitman
    pitman
    Lacquer cracks. Brittle.
    Enamel goes on thicker,
    More like a heavy glue.
    Acrylic lacquer
    and acrylic enamel
    are newer formulations.
    connielu, GTfastbacker and blowby like this.
  9. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Lacquer paint will gum up a 60 grit grinding disc in a jiffy.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Acrylic lacquer -1956
    Acrylic enamel -1968
  11. Lloyd's paint & glass
    I've been painting since vocational school in 1982 and I don't know of a way to tell them apart! I sprayed a lot of lacquer in the beginning, and I'd put Dupont 380S clear over it sometimes, then I've sanded and buffed an unknown amount of enamel jobs, so unless it's full of cracks (which can still be caused by too much lacquer primer under enamel) i have no clue. I'd say that some 2000 grit and soapy water, if it cuts clean, it's probably lacquer. But hell I don't know lol
  12. gimpyshotrods
    gimpyshotrods
    Lacquer ~ 7000 B.C.E.
  13. 57Fury440
    57Fury440
    What irishsteve said. Fast and easy way. My 57 was painted in 1981 with lacquer and except for a few areas that have cracks it still looks pretty good.
    stillrunners and vtx1800 like this.
  14. aircap
    aircap
    They are chemically different.
  15. T H A N K. Y O U. G U Y S
    for your great support!
    Joe
  16. lippy
    lippy
    from Ks
    They smell different in the can. :D
    belair likes this.
  17. bill gruendeman
    bill gruendeman
    My original 1939 flat lacquer will shine up with lacquer thinner and a rag, not even enough to do the whole car. And the rag turns black quickly.
  18. Truckedup
    Truckedup
    GM info says they stopped using lacquer in 1981...I don't know if GM was using lacquer on all vehicles or just some by 1981
  19. spanners
    spanners
    You can thin enamel with G.P. thinner for spraying but it you try to spray acrylic lacquer over enamel paint it will craze up and resemble hitting it with paint stripper.
    hotrodjack33 and irishsteve like this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    It really depends on WHY the OP needs to know ..there are so many different paints available that "enamel" could be most anything , from synthetic to epoxy to urethane to acrylic to catalyzed to heat cured to air dried to water based , tough to give an accurate answer ..
  21. HOTRODNORSKIE
    HOTRODNORSKIE
    Sprayed a lot of lacquer in the late 80s its hard and brittle. If its been on the car for a long time it will check somewhere. Enamel if not hardened will plug sandpaper. You will get a deep look on well sprayed lacquer job and almost chunky look on A enamel job.
  22. hotrodjack33
    hotrodjack33
    Tape off a small area that doesn't show. Lightly scuff with some 320 sandpaper. Spray the area with rustoleum clear lacquer (or similar). If it gets shiny again, it's lacquer. If it gets dull, or lifts/crinkles, its enamel.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    Not with any of the catalyzed or activated enamels .
