How to Drive With a Mini Spool
Discussion in 'The Hokey Ass Message Board' started by Mattilac, May 18, 2010.
  1. Not on a 9" Ford!
  2. BloodyKnuckles
    BloodyKnuckles
    Ok. Thanks.
    ******Knuckles
  3. bulletproof1
    bulletproof1
    from tulsa okla
    ok first make sure the park brake is off!!! most people put the park brake on when jacking a car up...(you know trying to be safe and all) and forget to release it ....ive sen it happen more than a few times..
  4. Country Gent
    Country Gent
    As the old school song went; "give me 40 acres and I'll turn this rig around". Only joken. Take in the previous advice on driving. That g***er I had in the 60s, was driven from North Carolina to New York and back with a 4:56 gear and locked rear.(Back then gas was cheap) Only thing I hurt was a couple of roller lifters on my Chet Herbert cam and they made good for it.
  5. outlaw56
    outlaw56
    from Hines, MN
    Run it! You will fine! I just laugh when "Naysayers" say u can't run a linclon locker, mini spool, or a spool on the street. Let us know how it goes, and prove the "naysayers" wrong!!
  6. Mattilac
    Mattilac
    So should I worry about the 1/8" play in the one axle or not? Its the driver-side, but that doesn't make any difference.
  7. 69fury
    69fury
    from Topeka
    play in/out? you said you haven't gotten the drums off yet- have you backed off the brakes using the s**** slot in the backing plate? If so then it sounds like it's just the drum frozen to the hub. take a hammer (deadblow if yer overly cautious and give 'er some whacks in between the wheel studs (dont hit them and booger the threads).
    rick
  8. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Ok, you didn't state that before. Sorry, then NO you should have no play in the axles on a 9" as the bearing is pressed onto the end of the axle and held in place with a plate. If you want I can PM you my phone #, I'll explain my expertise and you can listen if you want.
  9. Toner283
    Toner283
    Thread the wheel nuts back onto the studs before the hammer work. cheap insurance against f'ed up threads.
  10. I driven spool cars on the road not a big deal but the car does take a bit more effort to change lanes.
  11. Mattilac
    Mattilac
    Okay so it's been in there for about 150 miles now and the only difference I can tell is that I can do awesome donuts. It's fun and hasn't gotten me in trouble yet.
  12. Glad to hear you got it fixed and you're not having problems.:cool:
  13. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Copngrats.
