How to-engine turning. I'm looking for information on how to do engine turning.
Discussion in 'The Hokey Ass Message Board' started by tex34ford, May 12, 2008.
  1. tex34ford
    tex34ford
    I've done some searching but haven't found how to do it ie. how to do the panel layouts and then how to do the indexing etc. Any help appreciated.
  2. sko_ford
    sko_ford
  3. Asphalt Outlaw Hero
    Asphalt Outlaw Hero
    from Dixie
    I had a friend that use to take a pencil and chuck it up eraser side down.Put compound on it and go to it.
  4. VA HAMB
    VA HAMB
    I just did the dash in my 32 ( sorry no photo) I tried ALOT of different ways. The way I did it was to take small round pieces of scotch brite pads and press down with a pad chucked in a mill coating the dash with wd-40.It worked great. Change the pad every 5 spots or so using the same pressure and time cycle. If you have acces to a mill move the cycles in even spaces then offset the Dia move down and repeat. That way they cross each other a bit. Hope this makes sense. Ivealso been told that eastwood sells pads for this purpose.
    good luck T. Day
