How to figure curves?
Discussion in 'The Hokey Ass Message Board' started by d.reese, Apr 21, 2011.
  1. For everyone that subscribes to this thread, I want a dollar.
  2. hotroddon
    hotroddon
    no way - you didn't start it! :D
  3. dirt slinger
    dirt slinger
    Poor d reese. He will never get the answer he's looking for with all these jokers!
  4. hotroddon
    hotroddon
    nor will he without a complete question - Advance Curve, Power Curve, Torque Curve, Tubing Curve, French Curve, Road Curve, Body Line Curve ad infinitum
  5. Personally, I feel inspired by curves.
    There are many mathematical formulas to figure curves.
    look at these tires, lets say you wanted the to figure the cir***ference of the tire.
    Measure the diameter and multiply by PIE or 3.1416
    Simple!
  6. Thorkle Rod
    Thorkle Rod
    After she takes your money wrecks your car has you thrown in jail then you might have time to check this out:
    Given two bounded sets ​
    A and B in Euclidean space Em, we define dB(A) to be
    d​
    B
    (A) = sup
    a​
    ∈A
    d​
    (a,B) (1)
    where the distance from point
    a to set B is given by
    d​
    (a,B) = inf
    b​
    ∈B
    d​
    (a, b). (2)
    The point distance
    d(a, b) may be any distance in Em, such as for example an p distance.
    We refer to (2) as the
    minB calculation. In general dB(A) = dA(B). Letting Ballb() denote
    the closed ball of radius
    centered at point b, the Minkowski -sausage of B, denoted by
    B​
    , is the set
    B​
    b​
    ∈B
    Ball​
    b().
    So ​
    dB(A) is equal to the smallest such that A is contained in the -sausage of B.
    Sets
    A and B could be the graphs of curves. Then, in 2-dimensional space, A =
    (x(t), y(t)) : t ∈ [0, 1]} for some parameterized curve γ : t ∈ [0, 1] → (x(t), y(t)). Similarly
    for
    B.
    The Hausdorff distance between
    A and B will be taken as
    h​
    (A,B) = dB(A) + dA(B).
    This distance between 2-dimensional sets is important in image processing in which the sets
    are pixelized objects residing in a grid of ​
    M ×N pixels or cells. Two objects A and B in a
    black and white image are identical iff the Hausdorff distance between them is 0. Further,
    if one object is the translate of the other by a distance
    t, B = A + t, then h(A,B) = 2t.
    Letting
    |A| denote the number of pixels, or cardinality, of A, a straightforward computational
    implementation of (1) calculates
    dB(A), and hence h(A,B) also, in O(|A||B|) time.
    We refer to this as the
    Direct algorithm. However, it is possible to calculate h(A,B) for
    discretized binary sets in time proportional to the frame size,
    MN, in two dimensions (see
    (Shonkwiler, 1990) for the case of
    1 point distances and (Shonkwiler, 1991) for the general
    p
    case). We refer to these (collectively) as the Field algorithm, since the main idea is to
    step from one cell to the next over the pixel grid.
    Now suppose sets
    A and B are (discretized) curves. Their Hausdorff distance may be
    computed by the above mentioned algorithms, but neither is efficient. In particular the
    Field algorithm is inefficient since a curve is generally a sp**** subset of the complete pixel
    grid. In fact, if both
    A and B have Hausdorff dimension 1, then O(|A||B|) = O(MN). But
    for such 1-dimensional curves, one would think that an algorithm linear in their arc-lengths
    A|
    + |B| should be possible.
    In this paper, we give a new algorithm for calculating (1) with an average complexity
    of
    log(max(
    M,N))(|A|+ |B|) (3)
    2
    when an
    p point metric with p = 1 and p = ∞ is used. (There are special configurations
    of the sets for which (3) is violated when the point metric is
    1 or ∞.) We refer to it as the
    Scaling algorithm​
    , for its main idea is to refine an approximation of the distance h(A,B)
    by rescaling the resolution and doing the direct calculation for only a small subset of pairs
    a ​
    ∈ A
    and b ∈ B, which we call bridges. Unlike the Field algorithm, whose running time is
    independent of
    A and B, the Scaling algorithm’s running time varies with the number of
    points in the sets, as estimate (3) dictates. For curves, or more generally, sp**** subsets,
    and certain other subsets with widely separated points, the Scaling algorithm is faster. The
    algorithm works, with only minor changes, for the various
    p point metrics. The Scaling
    algorithm may be adapted to any space dimension; its advantage for sp**** sets increases
    with dimension. Finally, besides calculating the distance (1), the algorithm also produces
    the points on the curves at which this distance is achieved.
    In the next section, we present the Scaling algorithm in detail for two dimensions, but
    here we outline the main ideas. For the purposes of computation, we ***ume the discretized
    curves
    A and B live in an N × N square of cells, where N is a power of 2, N = 2R. This
    may entail embedding the given frame in a larger one. The algorithm proceeds in stages
    r ​
    = 0, 1, . . ., R and begins with the entire space containing A and B as one large block.
    Processing at a given stage consists of these steps:
    1 curve rescaling;
    2 bridge updating;
    3 minB (local) pruning, i.e. rescaling the
    d(a,B) candidates;
    4 maxd (global) pruning, i.e. rescaling the
    dB(A) candidates.
    Beginning with the crudest resolution possible, a single 1
    × 1 block, processing works
    in stages toward the highest resolution. In this way, many portions of both curves are identified
    early on as non-contenders in figuring into the calculation of
    dB(A). The remaining
    contenders are kept for further processing, the bridges, consisting of candidate pairs of
    blocks, or
    bridgeheads, from the representatives of A and B at the given resolution. To
    carry out the updating, the blocks serving as bridgeheads are refined according to their
    respective curves; this is step 1. Next, step 2: from the refined bridgeheads, all possibilities
    for new bridges are considered, but many of them can be eliminated as contenders.
    In step 3, the list is pruned by invoking equation (2) for each
    A bridgehead; this is a local
    comparison. In step 4, a global pruning is carried out based on equation (1), and every
    bridge length is compared with the current maximum.
    Following the detailed explanation of these steps, we give some intermediate results
    of the algorithm and the number of bridges at each stage, in a typical application.
    YOU WERE TALKING ABOUT BRIDGES WEREN"T YOU
  7. hotroddon
    hotroddon
    What Tires?
  8. need louvers ?
    need louvers ?
    I like ****s! ^^^^ Sorry, brain melting...
  9. Ellipses can be confusing **** fun.
    I use this alot, it help you figure how big of a piece to start with to get the compound curves.
    Approximations to ellipses An ellipse of low eccentricity can be represented reasonably accurately by a circle with its centre offset. With the exception of Mercury, all the planets have an orbit whose minor axis differs from the major axis by less than half of one percent. To draw the orbit with a pair of comp***es the centre of the circle should be offset from the focus by an amount equal to the eccentricity multiplied by the radius.
    Two perfect examples of elliptical curves gone compound.
  10. av8
    av8
    Sir Jackie Stewart summed it up best: "Exit speed is far more important than entry speed."
  11. I can't !
    I already gave my dollar to the Young Lady in post # 20
  12. d.reese
    d.reese
    Oh, there all close on the answer, I just happen to have a different angle!!!
  13. bykerlad
    bykerlad
    from australia
    What was the question again ?????????
  14. hartmen
    hartmen
    lovely thread guys
  15. aaggie
    aaggie
    She was a Pirates dream, sunken chest.
    She was a carpenters daughter, flat as a board.
    In figuring out sheet metal patterns Integral Calculus is handy for designing curves.
  16. Lucky3
    Lucky3
    What he said....
  17. Do I detect a note of sarcasm here?
    shouldn't you be sanding and slinging bondo?
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Thats how I figure them ,Whatever is pleasing to the eye..........
  19. Wow one of the greatest knocks ive ever heard on here. Damn!!!:D
  20. All good curve design involves the strategic use of H2o
  21. fbama73
    fbama73
    God, I love dagmars!
  22. rusty bill
    rusty bill
    divco13 where do I get a seasonticket?
  23. moefuzz
    moefuzz
    I figure if they aint got any then they're probably someones uncle in someones aunts underwear .
  24. Deuces
    Deuces
    Black stockin's and hi-heels... :D
  25. need louvers ?
    need louvers ?
    bwaaahaahaaahaa!!!
  26. Don't forget if the curves are to big you won't be able to get your hands around them.
    And they will eat you out of house and home too.
  27. mmmmmmmm pie!!
    BWAHAHAHAHAHAHA!!!!!! BURN!
