how to flat clear a patina paint
Discussion in 'The Hokey Ass Message Board' started by metalmen, Jul 3, 2013.
  1. metalmen
    metalmen
    from new jersey
    i seen that on the tv shows, i have a truck thats rust and sun faded is this something to really do or will it just peal and make it look like shit a year from now, or anything els to do to lock the look in
  2. Mr48chev
    A few hours with a Da sander and some 80 grit will get it down to where you can primer it and make something out of it.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Spend some time and do it right,,clear over rust is for those rat rod sites,,not the Hamb. HRP
  4. 117harv
    117harv
    So how do you PRESERVE a patina? Here is a thread with some info that will help. The search function will give you many more threads on the subject, and it's free.
  5. 296 V8
    296 V8
    from Nor~Cal
    Gasmonkeystyle = retarded
    kidcampbell71 likes this.
  6. metalmen
    metalmen
    from new jersey
    Geez relax I'm not gas monkey in anything I just have a original paint truck that's aged a bit it's only. Original once so I was trying to save it from gettin worst it not bad enough for a repaint just gettin thin on some spots , I hate that hack show just to let you know
  7. let it age as its doing now ....gracefully . or shoot it in primer sealer
  8. voodoo1
    voodoo1
    I would only take a scuff pad to it, then clear. Do not take 80 grit to it. Go to the paint store, get a decent clear and get a flatting agent for it. It's simple. If guys can go to flat black, satin clear is no big deal. Good luck. Mike
  9. HOTRODPRIMER
    HOTRODPRIMER
    How about a photo? HRP
  10. blowby
    blowby
    from Nicasio Ca
    A merchant marine friend used to take his aged motorcycle on the ship when he was working. He hosed it with floor wax.
  11. dana barlow
    dana barlow
    from Miami Fla.
    Patina? I guess I can't help,cuz that word to me is only a fanzy way of saying its screwed and needs fixing,give it some repect and put new shiny paint job. Having bad paint as a finish in not cool at all,any more then if you have a final finish of flat=primer,or satin=badly done shiny. Make it look good. Takes only a little more work and $ but last longer and looks better.
  12. Barn Find
    Barn Find
    from Missouri
    Store it inside and drive it often. You can't expect it to stay exactly like it is. It will age and that's OK. It won't rust away if you keep it out of the salt and wet storage. The best treatment is the oil from your hands and abrasion from use.
    Let it be real.
  13. Barn Find
    Barn Find
    from Missouri
    Paint is temporary.
  14. plym49
    plym49
    from Earth
    Another alternative is a 50:50 mix of kerosene and water. Shake well, dip rag, squeeze out, apply and let air dry. Water will bead and the patina will look richer and deeper.
  15. gilczbq
    gilczbq
    from london
    The search function will give you many more threads on the subject, and it's free.[​IMG]
  16. pastlane
    pastlane
    Use a flat wax, as opposed to the typical high gloss stuff. Hard to find in smaller cities, you may have to ask around...
  17. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Classic,,,, a FNG bringing up a post that had dropped down a few months just to call everyone trolls. :cool:
  18. mashed
    mashed
    from 4077th
    Fixed.
  19. farmeracb
    farmeracb
    I repair and restore antique tractors, and sometimes a repaint can actually reduce the value of an original one that is nice but has thin paint. I use a marine water based urethane over the original paint sometimes to bring out color and preserve. Try a little spot and see what you think. It sands back off easy for paint and can be touched up with a brush roller or spray gun without having to re do all of it.
    gas & guns likes this.
  20. T.L.
    T.L.
    from Colorado
    Patina is just a fancy word for "looks like shit", and an excuse for not spending money on a paint job. Basically, rat-rod garbage...
  21. chinarus
    chinarus
    from Georgia
    Keep it original paint as long as possible and call it a "survivor".
  22. harleycontracter
    harleycontracter
    Usually "patina" paint jobs done right would take longer than shooting it with color and being done with it. I'm not a painter just my opinion.More labor and more time. Patina paint jobs done right go into the booth with the option of being shiny black or patina from what I heard. But hey it's all what "we" like to look at ourselves. That's what makes all these cars hot rods and not production cars that all look alike.IMO
  23. harleycontracter
    harleycontracter
    Was responding to this post
  24. gtopillado
    gtopillado
    I think this is what your looking for: use a grey 3M scuff pad with a sanding paste like DX101, after its washed, dried and taped off, clean car with a wax and grease remover. You want to mix a catalized clear coat with a flattening agent...go for a egg shell-flat look. I prefer the egg shell, spray 2 medium wet coats and your done. This is what we use to replicate the finish on cladding moldings for most European cars. Keep in mind, the heavier coats you spray will give you more gloss, even with flattening agent. If you PM me with any PPG questions, I'd be happy to help out.
    Dave
  25. TheBartBarton
    TheBartBarton
    from Venice
    mashed, sounds like a personal problem. you ain't got no style bro. i'm sure you kicked the dog tonight too. What matters to me is I've got a nicely chopped 52 Chevy with a nasty big block, good brakes, suspension, custom wheels. I'll have to do something to the deck and radiator. Otherwise, pretty dialed in, a Harley dealer had it for 7 years after buying it from Rawlings and did lots to it. He has around 40 cars, all nice and radical, a well funded guy. It's no rat rod either. The style is Derelict but 6 years before Jonathan Ward started building them for $250k. The only other 50's era Chevy I've really liked on here is a flat red '52 by 345winder, he says he built and I have no reason to doubt....I paid $44.5 for it and I earned it so I can spend it wherever the fuck I want to. Enjoy.
  26. old soul
    old soul
    from oswego NY
    Im sorry. But in some cases patina is just down right cool. Not every one is going to have a nice mint paint job boring!!!!! Imagine finding a gasser barn find with no patina???? Im sure most would say yea that would be so great. But come on.
  27. midroad
    midroad
    If you have old paint it's patina. If you have rust it needs painting.
  28. theHIGHLANDER
    theHIGHLANDER
    Since we all have opinions about this, how hard would it be to keep them to yourself and just answer the question? Yes, you can flat clear but it won't look like the real thing. The advice above about flattening agent and not too much is right on the money. Just for the sake of saving $$$$ and labor, try to wax what you have 1st. Don't worry about the thin spots, and instead of a paste or white liquid use some Meguires Final Inspection or Quick Detail. Easy to use, beads water, doesn't "white out" if you're conservative with it, no difficulty removing for the day when new paint is desired. Just sayin, and good luck with it. I don't want you to like what I like, but would be happy to help you get what you want as easy as possible.
  29. blowby
    blowby
    from Nicasio Ca
    I agree. But putting clear paint over it makes it no longer patina. It's painted over patina. Preserve it some other way.
  30. 59Apachegail
    59Apachegail
    from New York
    I think I remember reading about someone using tung oil. I was going for the same but I scrapped the idea when I realized mine is in a heated garage and away from salt.
