Technical How to ground 63 ranchero tail lights
Discussion in 'Traditional Hot Rods' started by Indecisivebuilder95, Dec 4, 2016.
  1. I'm running new wiring and I just for the life of me can not figure out where to ground the old tailights with my new harness
  2. scrap metal 48
    scrap metal 48
    Just ground it to one of the mounting screws of the housing...
  3. Mike51Merc
    Mike51Merc
    My non-Ranchero Falcon taillights are grounded to the trunk floor with sheet metal screws.
  4. What I'm asking is do you just run aground wire from the housing to the body oristhere anouther wire on the tail light that should be a ground. I only have two wires by the way
  5. Mike51Merc
    Mike51Merc
    There should be a connector tab on the bucket for the ground wire. I think there is a factory sub-harness that grounds both tail lights and the fuel filler neck.
