How to identify Ford 8"?
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Sep 1, 2012.
  1. 36tudordeluxe
    36tudordeluxe
    Want to put Ford 8" in my '36 with a CE parallel leaf spring kit. What year Ford models had these, how do I identify and is there something that would tell me what the rear end ratio is?
  2. gimpyshotrods
    gimpyshotrods
  3. Deuce Roadster
    Deuce Roadster
    The JUNK mans way is too check the lower studs ...
    If you can get a deep wall socket on the bottom two studs ( shown above ) it is a 8 inch. If you cannot ... it is a 9 inch.
  4. uncle buck
    uncle buck
    This is by far the quick and easy id.
  5. 40FordGuy
    40FordGuy
    36,.. I used an 8" from a 2000 Explorer 2wd. Mine came with a 3:55, hat rotor disc brakes, and they even included the park brake cables. I paid $450 for it. That brake system is still in use, and parts can be found anywhere. Mine is under my 40 pickup, and I did have to re locate the spring pads, to work with the C.E. parallel spring kit.
    4TTRUK
  6. 40FordGuy
    40FordGuy
    The 8.8: unit mentioned above will (should?) have a tag on one of the upper rear cover bolts.
    4TTRUK
  7. 31Apickup
    31Apickup
    The 8" Ford rear was used in Mustangs & Fairlanes in the 60's, and in the Granada, Maverick, Mercury Comet & Mercury Monarch in the 70's I think the last year of production was 78 or 79. Nearly all have a highway gears 3.00 or less. The Maverick is the narrowest of them need to look for a V-8 in the 71 & 72's for the 5 lug rear, the later ones all had 5 lug. For a 36, a Granada/Monarch would be the best.
  8. 36tudordeluxe
    36tudordeluxe
    Thanks for the info. guys, much appreciated. I'll be looking for the 5 lug Granada.
  9. RFAGrasshopper
    RFAGrasshopper
    If you find a Mustang II or Pinto with a V-6 engine they will have an 8" with a 3:44 or 3:55 gear set and fit the maverick rearend just fine.
  10. Deuces
    Deuces
    My dad's ol' '72 Maverick "Grabber" had the 144 hp :eek: 302 in it with the 5-lug wheels...
