Hot Rods How to increase compression on 1937 Flathead
Discussion in 'The Hokey Ass Message Board' started by DocMcD, Mar 22, 2023.
  1. DocMcD
    DocMcD
    from Georgia
    I need to rebuild my 37 FH. If possible, I'd like to bump up the compression, but I'm not finding any options for piston/heads to do so. I am aware of the Sharp heads, but $1500 is a bit steep. Are there any other options or should I just build back original?
  2. Budget36
    Budget36
    You could have your heads milled. You have to be careful with how much though. Someone will let you know a safe amount you can have taken off, and the proper way to verify clearance.
  3. Hillbilly Werewolf
    Hillbilly Werewolf
    Only goes back to '38, I would bet it would be similar to your '37.
    Look up how guys deck blocks and dome above the piston for good quench. By tightening up quench you will gain some compression and efficiency.
  4. DocMcD
    DocMcD
    from Georgia
    Thanks Hillbilly. That may be my only option.
  5. Flathead47
    Flathead47
    from ontario
    Do a search on the Ford Barn , lots of information on milling heads , getting the proper piston to head clearance to wake a flathead up.
  6. tubman
    tubman
  7. alanp561
    alanp561
    BEFORE YOU CUT ANYTHING, put some clay on the heads above the valves and roll the engine over. Pull the heads and measure the thickness of the clay, BEFORE YOU CUT ANYTHING. Your heads or the block may have already been milled at some time. Ask me how I know.
    Okie Pete and WalkerMD like this.
