How to Installing Water Tranfer Decals?
Discussion in 'The Hokey Ass Message Board' started by Jay Tyrrell, Nov 16, 2011.
  1. Jay Tyrrell
    Jay Tyrrell
    Just what the ***le says. I am waiting on an original NHRA water tranfer decal that I want to replace the one that use to be fixed to the inside of the window of my 55. I am wondering if anyone has any tips? You only really get one chance at applying these things and I don't want to mess it up.
    Thanks
    J
  2. tfeverfred
    tfeverfred
    Uhh... soak it in warm water for a minute, slide into place, dab off excess water... let dry.
    Just like the ones with model cars.
  3. oldcarfart
    oldcarfart
    I use warm water with just enough DAWN detergent to make bubbles if agitated, same solution as tinting windows. Squiggee with credit card.
  4. Jay Tyrrell
    Jay Tyrrell
    What does the detergent do?
  5. mj40's
    mj40's
    I had a friend pay big bucks for an original decal only to screw it up in the install. Now it looks like it has been there the 50+ years it has been around. :D The outcome looks even better than a new looking decal.
  6. Judd
    Judd
    If this is an old decal make sure it isn't dried and cracked or it will fall to pieces when it soaks free from the paper. There are srays that will hold the decal together if it is. Try a local hobby shop for more info.
  7. Uh... is this a trick question???????
  8. tfeverfred
    tfeverfred
    I was gonna ask that, but I'm in a "kinder HAMB" mood.:D
  9. LongT
    LongT
    Fred your avatar is mesmerizing!!
    Anyway, I don't think water transfer decals are as common as they once were. Do they still put them in model kits?
    Bill
  10. dana barlow
    dana barlow
    from Miami Fla.
    It helps by giving you a little more time and slip to move the decals around and get it flat then just water;):D
  11. iammarvin
    iammarvin
    from Tulare, Ca
    Detergent actually makes water "wetter". It alloughs water to get deeper between substances. Therefore allowing the decal to move easier, thus the transfer decal is less prone to tear.
  12. rusty rocket
    rusty rocket
    go to your local hobby shop they should have products for decals. microsol, microset are some of the ones ive used when i built model cars. there also a product you can brush on older decals if there cracked.
  13. bonesy
    bonesy
    I purchased a set of 4 old Coke water slides from the early 50's.
    After killing 2 (they literally fell apart in water) I wanted to scream.
    Number 3 I coated very heavy in rattle can clear while it was still on the paper. The clear worked. It transferred over very nicely, not perfect but cool.
    Good luck.
    Here is a ****py picture of the results:
  14. jcmarz
    jcmarz
    from Chino, Ca
    It's not April Fools Day already is it?? What's next, how to use a rotary phone?!
  15. Dan in Pasadena
    Dan in Pasadena
    Really? Really guys? "Installing" a decal is some kind of "black art" requiring expert consultants to decipher the cryptic subtleties? HILARIOUS.
  16. hot rod rod
    hot rod rod
    I suggest.. trying Bud Lite...it bubbles. then they Pop. Then what left You can enjoy.
  17. BISHOP
    BISHOP
    Urine. It will crack up and fade if you dont soak it in urine.
    What kind of urine, you ask.......... well, urine from a crack head ho should have the best results.
    No offence to any crack head ho.
  18. abe lugo
    abe lugo
    guys, you can spray a few layers of clear lacquer over the decal to save it. To test this out cut out a piece of the decal that will get cut out any how, first give it a light mist let flash a bit them come in with a couple of layers. let dry. try it out.
    We make custom decals at work and we spray them over with clear lacquer to make the easier to use.
  19. iammarvin
    iammarvin
    from Tulare, Ca
    HAhahaha..............that is funny.
    I know the traditional way.
    :eek:
  20. Dan in Pasadena
    Dan in Pasadena
    Thank you, thank you, I'm here every night....literally!:p:D
  21. Jay Tyrrell
    Jay Tyrrell
    Thanks for the advice to the guys that acutally took the time to chime in with some good advice. I will definately try the detergent and clearcoating technique.
    To the rest of the of you that chimed in with nothing but ******** (newbie, member, and old school Hamber) I thought that is was a legit enough question. Take some time and read why the HAMB is here. It is about us talking about traditional rods and customs and helping one another out when we are maybe stuck on something. I am not too proud to ask for ***istance if I don't understand something completely. Sorry really don't know much about water tranfer decals. Never was one for building models when I was younger and I didn't want to **** it up.
    Jay
  22. tommy
    tommy
    Yeah I've been installing decals for over 50 years. I'm guessing the smart ***es have not tried to install an original decal since they were new. Repos are a piece of cake...originals can be a real challenge.
    The originals that I was trying to use had deteriorated to the point that the decal broke up into a thousand pieces. In the old days, I've been able to arrange the pieces like a jig saw puzzle. It would not work on my Wolf whistle original decals. I think they make repros but the originals just fall to pieces like a tempered gl*** side window. I have several original decals that I'll probably just use in the display case keeping them on the original paper.
  23. nobby
    nobby
    the soap, stops the water from forming droplets, having 'dry' areas
    surface tension and all that = science
  24. striper
    striper
    Probably just enough stories of guys destroying old decals and just enough advice on how to avoid doing that to make this a legitimate thread and to make the smart ***es look like smart ***es. Good question...good info. Thanks.
  25. sololobo
    sololobo
    Atta Boy Kid, give em hell, we don't have time for negative b.s. here. Good questions and some good helping hints. Good luck with the applications. ~sololobo~
  26. Oldmanolds
    Oldmanolds
    I've been looking for some small American Flag (maybe 1"X2") water transfer decals if anyone knows where to score some.
  27. I'm with Tommy here, the smart **** (Of which I normally are) replyers just have not done many of them. The older they are the harder to do, it is a black art.
    There is some good info here though.
    Microsol and Microset are great products unless the decal has deteriorated to the point you need to clear coat it, then don't use the Microsol and be very judicious with the Microset.
    (Microsol softens the decal, if it's deteriorated it helps it to fall apart)
    The clear coat info is all great stuff.
    Again if it has been clear coated don't use a credit card or anything to 'squeegee' it down, use a wet but well rung out sponge to 'dab' it down.
    Talk to 'Muttley' he may have a repo of the decal for sale, either way he has some great stuff check it out.
    Doc.
  28. Jay Tyrrell
    Jay Tyrrell
    Thanks for all the tips guys. Much appreciated! Wasn't sure what would happen to this thread over the day while I was at work but it looks like we got some real possitive and helpful info that has been added. Thanks again for the ideas, guidance and PMs. This thread has really come along with some super helpful info. At $10.00 a pop for a water tranfer it is definatley something that I want and other people would want to make sure that the application goes smoothly.
    Jay
  29. Nooo!
    How to use a "Push ****on" phone! :rolleyes:
  30. nobby
    nobby
    no one know a screen printed on here?
