I recently got this...... and right now there is a custom (nice but not my style) steering wheel on her..... how do i get the horn ring off ? how bout hookin up the horn ? how do i install a steering wheel ?? Maybe dumb questions... and i may be able to do it.... But i figured id ask somone whe knew first.... THANKS !!!!!!!!! Mark
Put your hand on the center hub. Push down to compress the retaining spring. (Might want to disconnect the horns or battery prior to on the horn will be honking until you get the hub off.) Push the hub down all the way so the hub is flat and not ****ed. Turn CCW about 50-70 degrees which will align the hub tabs with notches in the wheel's steel center cup. (I'm pretty sure CCW is the right way, if not go CW. Main thing is don't be pushing or pulling on the cast ring or you'll break it. You can use the ring to turn the horn hub/ring combo, but do it with reasonable force.) Once you have the horn wire/terminal disconnceted, removal of the wheel proper rquires a regular steering wheel puller. for the initial wheel pull, have the wheel/shaft nut at the top of the shaft threads. If you don't, the puller will spread the wheel shaft and you can't get the nut back on without some filing and many bad words. Used to own a Shoebox or two....
Just out of curiosity, is your custom wheel's cross spokes in the form of a shallow X and covered with ivory colored plastic? If so, it may be a factory made optional at the parts counter wheel. It may have been made for the Crestliners and came standard on them. Key thing is, it's a desirable wheel. Why not post some pics of it? If you're not gonna use it, some other Shoebox owner may want it.
where would i go about gettin a steering wheel puller... ?? and there are no wires for the horn.... anywhere... so ill have to re do that from scratch....... and is it gonna be some difficult crazy job that a newbie cant really do ? remember i am a fighter and have been hit in the head alot.... LOL Thanks for the help !! ps. 50shoe WOW I wish my steering wheel looked like that one.... Thats awesome !!! anyone know where to get one like that ????? no its a little custom (****) bought recently, one.... ill post some pics....
you should be able to pick up a puller for less than $20 at any napa, autoquest, etc.... Leslie makes a decent one. Good tool to have, you won't use it much but when you need it.... thats an accessory ford wheel from the early 50s, those and the crestliner wheels are going for north of $1000 IF you can find one!
Alright !!!! Thanks for the help guys ! I did it !! ( It may have taken me all day, and I may have broke a piece off the steering wheel) But I did it !! thanks for the help ... heres some pics !! Before After
There should be a wire running up the inside of the steering column for the horn ****on. It comes out of the steering box at the bottom.
Thanks automotive stud... but there isnt any wires there........ im going to have to start from scratch.... damn my car is dirty.... lol its my daily though.... sooooooo .....
I think you'll find a single screw in the horn ****on; a wire with loop terminal connects there and goes down the middle of the steering shaft. It connects to the gronding terminal of a relay...another topic when you get there...
holy ****, that carpet used to be light brown....can't you find a freaking vacuum in Vegas? And who bled on the seat?
