How to Lower My 48 Dodge Club Coupe?
Discussion in 'The Hokey Ass Message Board' started by christjazz1, Oct 11, 2011.
  1. christjazz1
    christjazz1
    Hi all,
    Can anyone give me tips on lowering my 48 Dodge Club Coupe on the cheap?
    Thank you,
    Michael:D
  2. scrap metal 48
    scrap metal 48
    For the back just throw 3 80lb bags of cement in the trunk.. Won't cost you 10 bucks......
  3. Flat-Foot
    Flat-Foot
    from Locust NC
    Doesn't get much cheaper than wacking a coil or two out in front and some lowering blocks in the back.
  4. Bart 56
    Bart 56
    For THE front you can put your mother in law on THE bumper, worked for me.
  5. hotskins
    hotskins
    from Justin Tx.
    Nice:)
  6. Kreepea_1
    Kreepea_1
    Flat-Foot called it! 1-1/2 to 2 coils cut and some lowering blocks. Depending on how low you go you may have to trim the lower control arm snubber to keep suspension from bottoming out and or get some shorter shocks. If you can get a copy of the June 1990 Street Rod Action there is a tech article on cutting coils and installing lowering blocks for your style car.
    There is also the option of installing dropped spindles up front, although not as cheap as cutting coils - unless you drop them yourself. The May 1991 issue of Street Rod Action has a tech article on installing Fatman Fabrication dropped spindles in the mopar. A tech article has also been written/posted on how to drop your own spindles. If I come across that article/post I'll post on the reference.
    One of the above mentioned articles cautioned about maybe needing to modify/drop your steering arm if dropping the suspension lower than 3" - 3-1/2" to avoid bumpsteer. There is also the option of buying a dropped steering arm.
    Hopefully, the mopar experts will chime in and get ya going straight and low.
  7. jimmygrrr
    jimmygrrr
    I say cut a couple of coils and block the back man. I was able to swap the coils on my shoebox for junkyard aerostar coils and blocked the back of mine for about $150 or so with new shocks. rides good enough for me!
  8. This is 1 coil cut on the front and 2" blocks on the rear, and 15 x 6, 15 x 7" rims & 195/75 x 15 and 235/75 x 15 Coker Cl***ic radials.......regards, andyd
  9. christjazz1
    christjazz1
    Thanks for the advice all. It sounds like cut coils and lowering blocks until I can install air bags.
  10. Smokeybear
    Smokeybear
    yep, that's the way to go on the cheap. Don't go more than 1 and 1/2 on the front at first, you want to sneak up on it. I've got 1 and 1/2 cut and a three inch block in the rear. 14s on the front, 15s on the back.
  11. tankwilson
    tankwilson
    Just Bag it!!!!!
  12. koolkat269
    koolkat269
    google eaton springs out of detroit. the best way to lowera car or truck.
  13. dana barlow
    dana barlow
    from Miami Fla.
    That one looks really great:D:cool:
