How to make 49-51 Ford and Merc trim clips and others from 1940's
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Dec 18, 2014.
  1. HomemadeHardtop57
    HomemadeHardtop57
    Ford and Merc trim clip tech taught to me by Foxy Elder, East Coast custom guy that left us several years back.
    These are the side window clips.. I make the rear glass ones too but that's for another tech post. These clips aren't too hard to make but are very tedious. The clip making tools I use were modified 30 years ago and passed on to me to keep the tradition going. I'll make some for you if you need help but give it a try.
    I start with a sheet of polished 26 ga. stainless. I then cut it into 3/4 inch strips. I have 6" pieces of stock Ford and Merc side trim that I make a duct tape handle on and use as a hand held fixture to bend the stainless around. Foxy use to slide a piece of rubber fuel line over his. I take the stainless strip and fold a 90 degree end on it only about a 16th of an inch in a vise that was set up with a special spacer the thickness of the metal with a 16th inch deep drop. I lay the strip down on the bench and with a small hammer knock that 90 down to about a 45. I have another tool that knocks the sharp folded edge into a more rounded one. ( that's the piece of metal in the one pic with my old blood all over it, wear gloves!!) the piece slides in the bend then I smack the top of the edge with a hammer. The fold becomes rounded slightly. This was a piece of 1/8th in flat stock ground down with a grinder and rounded at the top edge.
    I then grab my piece of stock Merc or Ford trim with the duck tape handle and take my piece of 3/4 in stainless.. Put the folded lip on the bottom of the trim and pull it up and around the trim piece I'm holding. I then check to make sure the front of the stainless is square with the excess wrapped around back. I trim the excess off with a cut off wheel or tin snips. Maybe a 1/4 in. overhang that gets fine tuned later.
    I then squeeze the clip top to bottom with a pliers to tighten it up and continue to make adjustments until it fits the trim jig nice.
    The Mercs have a slight raised crown in the middle also. To do this I have a piece of steel ( actually the front of the vise) with a small groove cut out the profile of the needed crown that I put the clip in facing down and use the steel as sort of a dolly. I put the clip in the groove, put a rounded off chisel inside the clip and hit it once. The clip face bends down into the groove and the crown happens.
    After they fit the trim piece I put them in a vise upside down and even out the folded over edges with a cut off wheel on a die grinder then they get buffed. If they are too loose fitting they can be squeezed with pliers. If they are too tight set them face up on a table and hit them lightly with a rubber mallet to open them
    When the batch is done they get polished to take the tooling scratches out but since it's pre- polished stainless it doesn't take much ImageUploadedByH.A.M.B.1418959950.688838.jpg ImageUploadedByH.A.M.B.1418959962.539234.jpg ImageUploadedByH.A.M.B.1418959974.049752.jpg ImageUploadedByH.A.M.B.1418959987.515234.jpg ImageUploadedByH.A.M.B.1418960009.965525.jpg ImageUploadedByH.A.M.B.1418960024.155697.jpg ImageUploadedByH.A.M.B.1418960037.155145.jpg ImageUploadedByH.A.M.B.1418960050.583980.jpg ImageUploadedByH.A.M.B.1418960076.149100.jpg ImageUploadedByH.A.M.B.1418960096.532307.jpg ImageUploadedByH.A.M.B.1418960107.962937.jpg ImageUploadedByH.A.M.B.1418960119.247445.jpg ImageUploadedByH.A.M.B.1418960132.420431.jpg ImageUploadedByH.A.M.B.1418960144.603439.jpg ImageUploadedByH.A.M.B.1418960155.590214.jpg ImageUploadedByH.A.M.B.1418960165.734264.jpg ImageUploadedByH.A.M.B.1418960177.360174.jpg ImageUploadedByH.A.M.B.1418960190.285619.jpg ImageUploadedByH.A.M.B.1418960200.940340.jpg ImageUploadedByH.A.M.B.1418960212.098455.jpg ImageUploadedByH.A.M.B.1418960225.074341.jpg
    drdave likes this.
  2. Very nice! I may end up having to do something similar for the stainless clips on my front windshield. I appreciate the tech!
    Jeff
