How To Make An Egg-Crate Grille
Discussion in 'The Hokey Ass Message Board' started by Abomination, Dec 11, 2008.
  1. Abomination
    Abomination
    This was brought up in another thread. Here it is for your enjoyment!
    First off, here's the link to the original:
    http://www.kitcarmag.com/techarticles/0801kc_hot_to_make_an_egg_crate_grille/index.html
    By Harold Pace
    photographer: Harold Pace
    One of the most visually important parts of kit and custom cars is the grille, since that's the first thing people see. In the 1950s, many custom cars featured grilles with square or rectangular patterns made from flat metal stock, which became known as egg-crate grilles. Many production cars also used similar grilles, including 289 street Cobras, most Ferraris, and the 1965-67 Sting Ray. Custom car builders usually made their own grilles from aluminum bar stock, and they're easy to fab yourself using only a tape measure, a chisel, and a table saw. I made one for my Devin project car, and although the first one was thrown in the s**** bin, I learned enough to not make the same mistakes twice!
  2. Abomination
    Abomination
    Follow along with the photos and captions and your replicar grille could be making a great first impression if you too decide to fabricate an egg-crate grille.
  3. Abomination
    Abomination
    Start by measuring your grille opening. Leave some extra room around the edges so the grille bars will disappear behind the edges of the opening. Think about how the grille will be installed and how you intend to mount it.
  4. Abomination
    Abomination
    You will need flat aluminum stock, which is available at hardware stores in various widths, thicknesses, and lengths. Pick a width and thickness you like, and then buy a 6 1/2-inch metal cutting disc the same thickness as the aluminum you are using (less than $2) with a 5/8-inch mandrel hole.
  5. Abomination
    Abomination
    You probably won't need many horizontal bars (I had four) that will need to have slots cut in their forward-facing edges. Clamp them to the sliding miter gauge on the saw, make sure they're square to the face of the saw, and center the saw blade to your center marks.
  6. Abomination
    Abomination
    The grinding action will leave some rough metal debris on the edges of the slots. Remove this with a sharp metal chisel, which is less likely to scar the aluminum bars than a file or power tool.
  7. Abomination
    Abomination
    Mark the aluminum bar with a fine-point Sharpie pen to indicate length and where the grille's cross-pieces will go on center. You may want to make a cardboard grille first to check how it looks before you commit to metal.
  8. Abomination
    Abomination
    You will need lots of vertical bars, and they will need slots cut in their rearward-facing edges. Cut to length and then securely tape them together on the ends with good duct tape. Then measure and mark where the horizontal bars will cross them.
  9. Abomination
    Abomination
    The newly slotted bars are ready for ***embly. Make a final check for the correct height of each slot.
  10. Abomination
    Abomination
    Replace the woodcutting blade in your saw with the cutoff wheel and adjust the height to half the width of the bar stock. Mine was 1 inch wide, so I set the blade to 1/2-inch above the table. Make sure the blade is perfectly vertical.
  11. Abomination
    Abomination
    Once again, set alignment, clamp securely to the sliding miter gauge on the saw, and push the bar stock over the spinning wheel. Make sure the cuts are all the way to the half-width mark and that they are perpendicular to the bottom of the bar.
  12. Abomination
    Abomination
    ***emble the grille by pushing the vertical bars over the horizontal bars. You may need to put the grille in a vise to push the parts together, but don't force it too much, as you may have a slot that is not deep enough.
  13. Abomination
    Abomination
    Make a set of brackets to mount your grille. I made a C-shaped piece of aluminum that bolts to the grille on the ends and mounts to the body with ****onhead cap screws. Each grille is different, so some other design might work better for you.
  14. Abomination
    Abomination
    Here's the finished grille mounted in Project Devin. It's just what I wanted, and at a price of under $40! You can leave it dull aluminum like I did, polish it out, or paint it any color you like...you can have your egg crate any way you want it!
  15. Abomination
    Abomination
    The AC Ace grille had different thicknesses of vertical and horizontal bars. This is more complicated but doable.
  16. Abomination
    Abomination
    The grille is designed to be held tight against the backside of the grille opening with the horizontal bars pushing the vertical bars against the edge.
  17. Abomination
    Abomination
    The Ferrari 500TRC sports a cl***ic egg-crate grille. Ferraris usually had an aluminum surround as well.
  18. Abomination
    Abomination
    The Stallion Cobra replicas used egg-crate grilles in both the radiator and oil cooler openings. Note that these have been painted black.
  19. Abomination
    Abomination
    Bump for the afternoon crowd!
  20. zzford
    zzford
    To ease your job and help make sure the spacing for the cuts are uniform, put a tab on your miter so that when you make the first cut, that cut will set over the tab. Then every cut that follows, you move the aluminum down to the next notch. I hope that's clear, kinda hard to put into words.
  21. Wildfire
    Wildfire
    Instead of the grinder blade, you can run a carbide tipped wood blade - ***uming its the right width. Cuts like ****er.
  22. Abomination
    Abomination
    Glad you guys liked it. I thought something like this might come in handy, so I ***imilated it, cited the source, and added it to the HAMB repository.
    ~Jason
  23. dana barlow
    dana barlow
    from Miami Fla.
    Great tech,very much like I did it also on my Jabro body H-Mod back in 1958,:cool:
  24. Sinner
    Sinner
    I'm surprised that abrasive blade didn't load up with aluminum.
  25. plym49
    plym49
    from Earth
    You can cut aluminum - even steel - with a woodworking blade.
    HOWEVER - and this is important! - you MUST mount the blade backwards. If the point of the tooth rotates into the metal you are cutting, not so good. If the back of the tooth contacts, no problemo.
  26. Since I have a soft spot for sports-rods this is one of the BEST tech threads in a long time!
    Now, anyone know of a Kellison for sale?
  27. Abomination
    Abomination
  28. Midwest Rodder
    Midwest Rodder
    This is a great thread!
  29.
