How to meassure a rear end? for a 50 Chevy
Discussion in 'The Hokey Ass Message Board' started by louder50, Aug 1, 2006.
  1. louder50
    louder50
    from Michigan
    I'm trying to find a rear end to convert my 50 Chevy driveline. I keep hearing 60" is what I need, but do I meassure from the backs of each backing plate or to the outside of the hubs or what?
  2. rockabillyjoe
    rockabillyjoe
    from Seattle
    Easiest is a rear end from a 70's Camaro. I've heard of people using an S10 rear.
  3. Big Tony
    Big Tony
    S-10 rear ends work best if your gonna bag the car cause it gives about an extra inch or so which can make a huge difference
  4. outside to outside, where the wheels bolt on.
    Backing plate to backing plate doesn't tell you squat.
  5. moparsled is right you measure from wheel surface mount to wheel surface mount
  6. Splinter
    Splinter
    I usually just go left cheeck to right cheeck. Not real scientific, but gives ball-park numbers.
  7. 60" is what the 70-81 Camaro rears measure...they work fine, but if you're running skirts, you might have to cut the inside lip a little. S10 4x4 rears work well and measure 58"...if I remember correctly.
    Bryan
  8. 327-365hp
    327-365hp
    from Mass
