Hot Rods How to measure front axle?
Discussion in 'The Hokey Ass Message Board' started by Karl Grossman, May 3, 2020.
  1. Karl Grossman
    Karl Grossman
    Looking for an add-on tube shock kit for 1941 Ford 1/2 ton. How do you measure the axle (ie: 46" , 47 3/4' etc.)? Any recommendations for reasonably priced kits? Thanks
    dana barlow likes this.
  2. 41rodderz
    41rodderz
    from Oregon
    You measure from center of kingpin hole to center of kingpin hole and the same for spring perch holes.
  3. 41rodderz
    41rodderz
    from Oregon
    Speedway Motors is probably the most economical except maybe Johnny Law :oops: but you either should buy quality or get the shocks and make your own mounts if at all possible.
  4. 41rodderz
    41rodderz
    from Oregon
    I mean eBay may have deals but then you got to figure is it worth it to have to repair or replace shocks and mounts in the near future.
  5. 41rodderz
    41rodderz
    from Oregon
    Also another measurement is at the kingpin boss (top to bottom). Some are 2” and some are 2 1/4. Are you positive it is the original axle?
  6. Fordors
    Fordors
    All ‘28-‘48 axles have a 2 3/8” king pin boss. There are differences in perch bosses, ‘32-‘36 are 2”, all others are 2 3/8”.
  7. nobby
    nobby
    are you wanting to fit a 4'' dropped axle , with reversed eye spring,
    tube shocks, with the split wishbone - extra drop steering arms?
  8. gimpyshotrods
    gimpyshotrods
    My Model A and not '32-'36 axles measure 2-1/4 at the spring perch boss. I have never seen a 2-3/8" one, on anything but a V8-60 axle.
  9. Fordors
    Fordors
    Correct. Brain fade on my part, I meant to say 2 1/4”. Proof reading is your friend, 2 3/8” only applies to all king pin bosses.
  10. linechaser32
    linechaser32
    from Iowa
    Do not buy from Johnny Law. Part of the Hoffman Group. All junk!
    dirty old man and gimpyshotrods like this.
  11. nobby
    nobby
    c
  12. gimpyshotrods
    gimpyshotrods
    Exactly!
    dirty old man and olscrounger like this.
