How to mount a vintage bajo wheel to a hot rod column ???
Discussion in 'The Hokey Ass Message Board' started by FalconMan, Feb 17, 2009.
  1. FalconMan
    FalconMan
    from Minnesota
    I want to change out the steering wheel in my RPU. I bought a real nice original 36 ford banjo wheel. My RPU has one of the hot rod columns that uses a 3 hole mounting flange to mount the wheel.
    I have looked for an adapter with zero luck.
    My choices are:
    Make my own adapter ?
    Replace the column wit a vintage truck column ?
    Anyone done this before ?
  2. PASTDUEBILL
    PASTDUEBILL
    If it were me, I would use the vintage column at the top and attach it to your existing steering with a u joint down toward the box.
  3. FalconMan
    FalconMan
    from Minnesota
    I don't have a vintage column.....
  4. blackout
    blackout
    You need a sector shaft with a keyway to match your banjo wheel. Cut off the end of it, weld it to your existing shaft.
  5. motoandy
    motoandy
    from MB, SC
    I made my own adapter to use a 38 chevy wheel on a Speedway 3 bolt column. Not the prettiest, but it works.
  6. FalconMan
    FalconMan
    from Minnesota
    That's exactly what I was thinking of doing ! I am just wondering if I would be better off just replacing the column.
  7. PASTDUEBILL
    PASTDUEBILL
    But you don't have a vintage column..............
  8. Normal Norman
    Normal Norman
    from Goshen IN.
    I think Speedway sell an adapter for that. N.N.
  9. FalconMan
    FalconMan
    from Minnesota
    I think they sell an adapter that goes the other direction, stock column to a 3 hole wheel.
  10. FalconMan
    FalconMan
    from Minnesota
    I am sure they are available somewhere ...............
  11. sawzall
    sawzall
    my solution was similar to what motoandy did
    but the result was that I could "see" the adapter. so made a "trim" piece..
    sorry i dont have a better shot of the adapter but heres the "trim"
    http://recycled40fordwoodie.blogspot.com/2008/06/thanks-buddy.html
  12. zzford
    zzford
    Although I don't see it listed now, Speedway did have the adapter you need. It was used to mount the Model T style wheel to a bucket T's column. You might try giving them a call to see if they still stock it.
  13. What kind of steering box are you using?
    Is the three flange adapter welded onto the aftermarket hot rod shaft?
    Is the aftermarket hot rod shaft 3/4" OD?
    Within the last couple weeks there's been an article posted about mounting Ford wheels on GM steering shafts.
    Found it, go here: http://www.jalopyjournal.com/forum/showthread.php?t=334471
  14. tommy
    tommy
    Total performance also had a tapered stub piece with the slot for the woodruf key that could be welded to any 3/4" shaft. They were very popular in the early days of T buckets and probably still available.
  15. 8-Ball
    8-Ball
    Nice job,btw that is a 39 wheel. the 36 wheel has the spokes straight into the hub, the 39 spokes taper out as they come into the hub. nice wheel i got one on my 35 pickup. 8-Ball
  16. kenagain
    kenagain
    from so cal
    Make your own adapter n cover it up with a stainless or chrome glass with bottom cut out
  17. FalconMan
    FalconMan
    from Minnesota
    Well... I called Speedway/Total performance today. No such animal or even the tapered stub. So I guess I'll have to make my own with a little creative grinding and welding. A cover made out of a stainless cup is a great idea.
    If I could find a 35-39 column, I would prefer to just change it out and deal with it at the other end.
    You would think there would be a market for adapters for those running vintage wheels.....
    Thanks guys !
  18. I have a somewhat similar problem..... I need to adapt my splined 40s Stude wheel to a tapered/keyed VW Kombi column. I'm watching this thread with interest.
  19. Crankhole
    Crankhole
  20. Crankhole
    Crankhole
    Does a Model T wheel have the same taper and key as '28-'48 wheels?....'cause that is what Speedway says this will fit.
  21. FalconMan
    FalconMan
    from Minnesota
    BINGO !!!!!!!!! That's what I want. I talked to the tech guys... I searched their site with 'key' words .... and came up empty. You guys are great ! The rest will be easy.
    The other piece of the puzzle will be the horn button. I don't need it functional. The stock one had this narrow 4 inch shaft that goes into the stock column. I guess I need to cut it down to an inch, drill a hole in the above piece I buy from speedway, and RTV in place ????
  22. FalconMan
    FalconMan
    from Minnesota
  23. motoandy
    motoandy
    from MB, SC
    Sawzall did a killer job. I to intend on cover it up some. I just used what I had. Speedway could not help me. That is where I bought the column from. Good luck and post what you end up with.
  24. HotRodDaddy-O
    HotRodDaddy-O
  25. FalconMan
    FalconMan
    from Minnesota
  26. Crankhole
    Crankhole
    Do the early steering wheels have the same 7* taper as a tie rod end? Maybe an adapter could be made using one of those, if so.
  27. Kerry67
    Kerry67
    There is always wire ties & zip locks.
  28. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    We make a banjo column that will work, taper & key at the top , 3/4 36 spline at the bottom with a wire for a working horn , not cheap but it will work & has ball bearings top & bottom .(Stainless steel , plain or polished ) Sorry for the ad but it is a solution.
  29. FalconMan
    FalconMan
    from Minnesota
    Well, that's the correct solution. I'll keep it in mind. Thanks !
