how to protect bare metal ground???
Discussion in 'The Hokey Ass Message Board' started by Dan, Sep 16, 2009.
  1. Dan
    Dan
    Everything you says to s****e any areas where a ground is attached down to bare metal to get a good ground, makes sense. How do you protect the area to keep it from getting all rusty and thus getting a bad ground (this is the exterior of the vehicle obviously)??? thanks
  2. GEORGIADAWG
    GEORGIADAWG
    If it's not in the weather then you could use the stuff from any auto parts store to stop battery terminal corrosion. After you attach the ground and it's tightened down you can paint over what's left also.
  3. squirrel
    tar. spray on grease. paint. Move to AZ. lots of ways to do it.
  4. Alienbaby17
    Alienbaby17
    At the shop I've had bad luck with the cans of battery terminal protectant. It seems like it never dries and always remains kind of wet. I always end up rubbing my arm or something else across it while trying to do something and it smears off. I started to use the NAPA disc brake quiet spray (used on the back of pads). It's something we already had in the shop, dries after a few minutes and doesn't come off easily. Works for me.
    Jay
  5. Petroleum jelly. I don't know what you call it in the U.S., it's like KY jelly, but not as much fun.
  6. FIFTY2
    FIFTY2
    I always make my connection to bare metal then paint it, the ground wire terminal and metal are still touching.
  7. Um, we call it PETROLEUM JELLY:D
    Dan, you missed one hell of a good swap this last week!
  8. F-6Garagerat
    F-6Garagerat
    Spray it with Gibbs.
