How to re-use used rubbers...Tech post
Discussion in 'The Hokey Ass Message Board' started by Honest, Dec 21, 2003.
  1. Honest
    Honest
    from Dallas Tx
    Dont throw away that bald ass 4 ply "non-radial" tire.
    Use a hole saw and cut body mount rubber washers out of em.
    The center bolt hole is already there when you cut em too!
    also..im using the bottom part of a road construction thingy.. { not a cone, but a big rubber pad that holds up a larger square "cone"} for my motor mounts. Just cutting out a peice with the hole saw as above.
    Re-using rubbers is good for the enviroment B?]>
  2. dondanno
    dondanno
    Damm good idea, after all hot rodders are the original recyclers...Danny
  3. Unkl Ian
    Unkl Ian
    The big mud flaps off trucks,if you can find one,are thicker than the sidewall of a tire.
  4. hotrodladycrusr
    hotrodladycrusr
    [ QUOTE ]
    [/ QUOTE ]
    Yeah, but they'll all stretched out after just one use [​IMG] [​IMG] [​IMG]
  5. Honest
    Honest
    from Dallas Tx
    Not responding here....and responding on a junk post... tells the tale girls and boys.
  6. Hackerbilt
    Hackerbilt
    Works GREAT!
    Bill
  7. briggs&strattonChev
    briggs&strattonChev
    thats a good idea! How thick are they? Are you using the tread or the sidewall?
    semis have a rubber strap belting (from 2" to 5" wide and as long as you want if you get a new roll) that goes between the fuel tanks and the metal bands that hold them on (to keep the bands from scratching and wearing through the tanks) and ive used that as body mounts.
  8. manyolcars
    manyolcars
    I cut strips out of sidewalls for muffler hangers
  9. modernbeat
    modernbeat
    from Dallas, TX
    Yep, I made my engine and trans mounts from old bald Firestones.
  10. DrJ
    DrJ
    Some industrious and talented artisans have been known to make some bullet proof sandals out of them too.
    I think they call them Huarachis in T J [​IMG]
  11. Jethro
    Jethro
    What do you do with 400 used condoms???
    Make a tire out of it and call it a "Good Year"(insert cymbal crash here) [​IMG]
    ...Try the veal folks I'll be here all week ... make sure to tip your waitress!
  12. briggs&strattonChev
    briggs&strattonChev
  13. Elrusto
    Elrusto
  14. spudshaft
    spudshaft
    I thought to re-use a rubber you just turn it inside out?? [​IMG]
  15. Kevin Lee
    Kevin Lee
    Super Moderator
    Good one Honest. I'll add to it with this. Hockey pucks = motor mounts.
  16. Smokin Joe
    Smokin Joe
    Use Gin-u-whine "Gum Dipped Champion wide whites"
    If you tip the waitress, it's considered good form to at least help her up again!
    DrJ We used to call them Jesus Boots, but that was North of TJ.
    Actually, this is a good idea. This being drama week tho, you can't just let a tech idea sneak by without comment. [​IMG]
  17. tommy
    tommy
    Don't forget the inner tube while you're at it. It makes great anti-squeek material and lots of other uses. I use it for through the floor pedal seals.
    My rubbers never got stretched that much but that's a personal problem [​IMG]
