How to remove 1952 f1 cab pleaseeeeeeee
Discussion in 'The Hokey Ass Message Board' started by abashee, Mar 19, 2011.
  1. abashee
    abashee
    from Australia
    my dear friends, i am looking at restoring my first F1 truck which came to me all day way from nebraska....i have done all the majort rust repairs but will now likew to remove the cab to detail the frame.
    How do i remove the cab?
    What do i need to watch out for? will te steering column be a problem?
    its a three on the tree, so will there be any issues with cables to the ******?
    If anyone can or has a step by step guide it will be very appreciated.
    Thanks in advance
  2. 31ster
    31ster
    There should be a bolt on each side next to the front a pillar and a bolt on each side on the front edge of the cowl. This one I believe is on the engine bay. You then have an arm on each side in the back that connects to the side of the frame which is prone to crack. You can leave the column on if you have something high enough to lift it with to clear. And then you have the usual fuel lines and wiring etc.
  3. abashee
    abashee
    from Australia
    thanks 31ster...is there a special way to remove the steering wheel? i have removed the nut but short of bashing it to an inch of its life, is there a trick to this? is there any tools to remove the steering wheel?
  4. 55 dude
    55 dude
  5. old soul
    old soul
    from oswego NY
    Steering wheel puller Id say
  6. HOT40ROD
    HOT40ROD
    from Easton, Pa
    You can also unbolt the steering box from the frame and let it swing down so that all you have to do is walk the cab to the back of the frame. There is a plate on the floor around the column that will have to be removed. This plate is a couple of pieces and remember how you took it apart.
    The steering wheel will have to be removed with a wheel puller.
  7. CharlieLed
    CharlieLed
    X2...there are quite a few truckers on the FTE from the land of OZ, you may just find some local blokes there to help you.
  8. tb33anda3rd
    tb33anda3rd
    the pedals also will get hung up on the floor. you have to kinda tilt and lift it past them while watching not to scratch the firewall. hang a blanket over the engine.
  9. charleyw
    charleyw
    Don't forget the e-brake cable.
  10. abashee
    abashee
    from Australia
    thanks fellas, she is out !!! actually worked well...now the same for my COE...a bit heavier I would say.
