Technical How to remove and install a new passenger window
Discussion in 'Traditional Customs' started by Hashit51, Dec 2, 2015.
  1. Hashit51
    Hashit51
    1951 Ford Shoebox
  2. Jalopy Joker
    Jalopy Joker
    easier than drivers side window - Ha! pretty basic but, have no visual to help show you. post a pic of your door.
  3. Buddy Palumbo
    Buddy Palumbo
    First thing I would do is buy a copy of the "green bible " . Then I'd pay close attention as I took it apart, following the instructions in the book , and then I'd put it back together on reverse order . Glad to be of help , lol !
  4. Hashit51
    Hashit51
    Hey guys, thanks for the replies. I'll shoot a pic of the door right now.
  5. Hashit51
    Hashit51
    The P***enger door
  6. Hashit51
    Hashit51
    Outside the p***enger door
  7. Buddy Palumbo
    Buddy Palumbo
    Seriously, it's not that difficult, these cars are pretty simple. I was serious about buying the green bible ( I believe Shoebox-central has it). It's a great resource .
    Off the top of my head, pull the garnish molding off the inside, then the door panel. The regulator is only held on by a few screws , undo them . From there you should be able to get the regulator of the lower gl*** track, then list the gl*** up out the top . May have to loosen up the vent window to get the gl*** to tip in , I can't remember . It's only held on by a few screws as well . Reverse to install.
  8. seb fontana
    seb fontana
    from ct
    20 minutes to take out..2 hrs to put in..buy the bible is the best instruction you can have..
  9. Hashit51
    Hashit51
    Thank you @buddypaluma
  10. Hashit51
    Hashit51
    Is there an easy way to take off those door handles?
  11. Jalopy Joker
    Jalopy Joker
    to see a schematic of a shoebox door , not exact same year as yours, but gives you a good idea on how things go together/come apart search online - www. shoeboxford.com/public/department43.cfm - then search - macsautoparts.com - search there for window crank clip to see what holds handle to crank, next for inside door handle and window crank c-clip removal tool. can look for handle, etc to help see how parts look.
  12. Hashit51
    Hashit51
    Thanks brother
  13. Buddy Palumbo
    Buddy Palumbo
    I believe the 51's use a hairpin type clip to hold the handles on. Push in on the spring loaded bezel and you should be able to get to the clip. My 49 has a pin arrangement.
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    First roll the window all the way down you will notice the rollers in the window track and see a clip like the ones below in them put your thumb and fore finger and hold it together and pull out the clip that frees the track from the regulator and then you can tilt the track and pull it out,you will find the same style clip on the handles this hook tool is good for removing them. http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. Hashit51
    Hashit51
    Thanks for the info.
    Are you talking about these two rusty regulators?
  17. Atwater Mike
    Atwater Mike
    Pull the regulators out, using a liberal amount of JB Blaster on every moving part!
    When they're out, they're easy to clean and de-rust...really only 'strap steel'...
    JeffB2 has found the best upgrade you can do, use it!
    When you get it all apart, steel wool and sandpaper will aid you...(don't forget to paint the bare metal!)
  18. Hashit51
    Hashit51
    @JeffB2,
    Bascially, if I take out these pins. I don't need to take out the door handles.
  19. Hashit51
    Hashit51
    Thanks A****erMike for the tip. I'll use it.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
    Not until you want to put on a door panel ;)
