Projects How to remove bolt from crank
Discussion in 'The Hokey Ass Message Board' started by Shark49, Dec 28, 2025.
  1. Shark49
    Shark49
    It’s stuck on pretty good. How do I remove?
    Deuces likes this.
  2. Tim
    Tim
    from KCMO
    I would think make the flywheel immobile and a socket/ breaker bar
    Deuces, LOU WELLS and Johnny Gee like this.
  3. George
    George
    If all else fails, drop the pan & block the crank.
    Deuces likes this.
  4. Shark49
    Shark49
    How do you safely block the crank?
  5. Jam big old screwdriver on the flywheel ring gear ( thats what the starter hits ) Have someone hold the screwdriver so flywheel can't turn. Now if it's really really tight carefull you don't tip the whole engine stand over.
    Deuces likes this.
  6. Hollywood-East
    Hollywood-East
    I'd use an impact ??
    Is this a trick question?
  7. squirrel
    show us a picture of the back of the engine...then we can suggest how to keep the crank from turning.
    Deuces and Tow Truck Tom like this.
  8. Profile says we are dealing with a lady:cool:. Girlpower everywhere these days :cool:.
    Deuces likes this.
  9. Hollywood-East
    Hollywood-East
    Fair enough... Cheer's
    Deuces likes this.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Bahdda Bing Bahda BOOM
    jimmy six and gimpyshotrods like this.
  11. 302GMC
    302GMC
    from Idaho
    I got a Chicago Pneumatic 734 I bought in '68 that'll get it out in 10 seconds.
    Deuces likes this.
  12. Impact wrench without a doubt. If it was loc***ed, you will have a terrible time with a breakover. I have been down that road before on a newer engine.
    Deuces and firstinsteele like this.
  13. Hollywood and wfo are spot on. The jarring of the Impact works for me, anyway.
    Ben
  14. inthweedz
    inthweedz
    Take out a spark plug, wind the crank to bottom dead center, feed enough rope thru the plug hole to lock the piston when turning the crank back to top dead center.
    Now try your power bar and socket again, when bolt is free/undone, turn the flywheel to release the pressure on the rope and remove it from the plug hole..
    A whack on the bolt head might work as well..
    Deuces likes this.
  15. FrozenMerc
    FrozenMerc
    Use one of these.
    Deuces, TagMan and pwschuh like this.
  16. 28rpu
    28rpu
    Maybe it's left hand thread:rolleyes:
  17. gimpyshotrods
    gimpyshotrods
    One ugga-dugga.
    VANDENPLAS and Pocket Nick like this.
  18. Budget36
    Budget36
    If you don’t have an impact wrench, use a 1/2 inch breaker bar with a shallow socket.
    Use a heavy hammer, like a hand sledge, smack the breaker bar.
    That’s one mini-impact.
    Wear eye protection, gloves, disconnect the negative battery lead, etc, etc.
    Deuces and Joe Blow like this.
  19. seb fontana
    seb fontana
    from ct
    Righty tighty lefty loosey
    Deuces likes this.
  20. 28rpu
    28rpu
    Not necessarily
  21. RmK57
    RmK57
    Piston stop if the heads are on.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Never for this situation.
  23. Don't forget to leave a bit of the rope hanging out the spark plug hole!
    inthweedz, Deuces and firstinsteele like this.
  24. RmK57
    RmK57
    Why not?
    Deuces likes this.
  25. rockable
    rockable
    Because you might bend a rod but best case you will leave a dent or burr in your piston,
    Driver50x, BJR, Moriarity and 2 others like this.
  26. DDDenny
    I've had some luck using a 3/8" manual impact driver, sure, they say they are only meant to be used on small bolts but the shock using a small sledge hammer may loosen it, try a couple clockwise and counterclockwise hits, they also make 1/2" versions that may be better suited for your application.
    leon bee and Deuces like this.
  27. I think it's stuck due to turning engine over with the bolt, but no balancer present. So, not likely too tight. Impact, or right size box end, and a couple or raps with a sledge or heavy ball pein hammer, in the right direction, should do it.
    Johnny Gee likes this.
  28. RmK57
    RmK57
    Looks like a new build, cheap grade 8 bolt that was used to spin the engine around. 40-60 lbs. torque? Anyway I’ll have to write this down in my journal of things not to do.
  29. Beanscoot
    Beanscoot
    If using a breaker bar and smacking it, I've learnt that a two foot piece of 2x4 works way better than a hammer which is likely to glance off the polished round bar.
    clem likes this.
  30. goldmountain
    goldmountain
    Put a socket on the bolt along with a long braker bar jammed against the frame and hit the starter ****on (switch). Just don't do this on a reverse rotation Honda engine.
    Jokester and gimpyshotrods like this.
