Projects How to remove bolt from crank
Discussion in 'The Hokey Ass Message Board' started by Shark49, Dec 28, 2025.
  1. SS327
    SS327
    What does it matter if she’s a girl? I’ve seen many guys come here and ask far stupider questions. :(
  2. Deuces
    Deuces
    It is on a Ford motor....;)
    Algoma56 likes this.
  3. pprather
    pprather
    I wanted to remove crank bolt on my sbc. It was tight and the engine was in the completed rod.
    I put the breaker bar with 12 point socket and bar about 2" above the left frame rail.
    Cardboard protection behind radiator.
    What could go wrong?
    Engaged the key starter for a fraction of a second.
    Bolt loosened? Viola!
    Lil 32, Kerrynzl, leon bee and 2 others like this.
  4. Beanscoot
    Beanscoot
    I think the engine is not in a vehicle though.
  5. leon bee
    leon bee
    I'm surprised nobody has mentioned the BFH and chisel method. That'll get it off.
    34 GAZ and dogwalkin like this.
  6. oldiron 440
    oldiron 440
    Depends on what you hit with the chisel:)
  7. Driver50x
    Driver50x
    Yep. Those things are cheap, and super useful. It seems that very few people own one.
    ClayMart and leon bee like this.
  8. leon bee
    leon bee
    We have a no-name 1/2" drive one of them that's been used at least 1000 times. Motorcycle guys have these a lot.
  9. Driver50x
    Driver50x
    They work excellent on Phillips screws also.
  10. partsdawg
    partsdawg
    from Minnesota
    1/2" breaker bar with shallow socket and a 6' cheater pipe.
    Have a second socket ready after you crack the first one.
  11. jimmy six
    jimmy six
    302GMC, Algoma56 and alanp561 like this.
  12. We used those sledge wrenches at work, but ours were for much larger bolts and nuts.
  13. Acres
    Acres
    from Sweden
    Great easy cheap tip, learned when young and were working on twostrokes
  14. Happydaze
    Happydaze
    I find a 1/2" breaker bar can be a scary thing with a really stuck bolt as it gets flexible and springy. Not so with a 3/4" breaker bar. They stay really solid even with a 3 foot extension tube with 250lbs swinging on it. Can release with a good crack, but no flying objects!
    However, in the case in question I'd imagine a 1/2" would have it away without drama.
    Chris
    Beanscoot likes this.
