how to remove chevy headlight trim
Discussion in 'The Hokey Ass Message Board' started by DirtyJohnDeereHat, May 10, 2013.
  1. DirtyJohnDeereHat
    DirtyJohnDeereHat
    I know this may sound dumb, I feel silly not being able to figure it out. but I have a 1950 chevy coupe and I need to aim my headlights, how do I remove the trim? I can rock it left to right a little and pry it out some also, I don't want to mess it up by ripping it off.
  2. chaddilac
    chaddilac
    Should slide up, I think... been a while since I removed mine!
  3. DirtyJohnDeereHat
    DirtyJohnDeereHat
    Slide up? I don't see how it can slide up with the headlight still inside of it.
  4. Dave Downs
    Dave Downs
    from S.E. Penna
    From memory (to lazy to go look at mine...) should be a screw at the bottom of the trim ring, remove screw, pull bottom of ring out and lift up
  5. themoose
    themoose
  6. DirtyJohnDeereHat
    DirtyJohnDeereHat
  7. Rickybop
    Rickybop
    That's right.
  8. chaddilac
    chaddilac
    You have to pull it out a little at the bottom to get around the headlight.
