how to remove debris from ontop of plugs?
Discussion in 'The Hokey Ass Message Board' started by snortonnorton, Jun 20, 2006.
  1. snortonnorton
    snortonnorton
    from Florida
    My friend's truck won't start and we want to check the plugs, but it has sand and dirt covering the plug holes to the point that a socket cant grab them....
    the truck location has no access to air compressor as that would be the only way to blow it out,
    if i pour anything like PB blaster, would that work, or just make a mess.
  2. 47bob
    47bob
    Leave the plugs in and squirt them with your garden hose.
  3. snortonnorton
    snortonnorton
    from Florida
    yeah, guess that is best choice, was gonna use a pressure washer, guess we'll cover the dizzy and wires up.. thanks.
  4. ray
    ray
    from colorado
    spend $15 and go buy a portable air tank.
  5. mrrocket
    mrrocket
    Cover your carb, too. sounds obvious, but....
    OR, go to a computer store and get a couple cans of compressed air used for electronics...easy and cheap.
  6. Brad54
    Brad54
    from Atl Ga
    Long extension cord and a shop vac.
    If that doesn't do it, a hand-held wisk broom, or some other small bristly device. Scrub a bunch, and it should all come out.
    -Brad
  7. 55olds88
    55olds88
    Tooth brush, screw driver and a short lenth of hose to blow through ought to do it, hell its not like you are moving huge chunks of stuff.
  8. krusty40
    krusty40
    Can of air like you (should) use to clean your computer keyboard.
