How to remove trim rings ?
Discussion in 'The Hokey Ass Message Board' started by hotrob32, May 14, 2013.
  1. hotrob32
    hotrob32
    from Bend
    I'm gonna send my wheels out to get powder coated a different color, and Im wanting to get the brand new trim rings off without damaging them.
  2. tfeverfred
    tfeverfred
    They dig into the wheel. That's how they stay on. I don't see how it could be done.
  3. mashed
    mashed
    from 4077th
    I know they make high-temp fibergl*** masking tape for powder coating. Ask your powder coater what they'd suggest first.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Just use a big screwdriver and gently work around the trim ring. HRP
  5. malcolm1943
    malcolm1943
    if the picture you posted is the rings your question is about they should pop off like a hubcap. I heated a cheap screw driver and bent the tip to a 90 about two inches up from the tip, blunted the tip a little and use it to pry from the inside edge, carefully and working my way around the perimeter. Hope this helps!
  6. BobF
    BobF
    from Poway, CA
    I've always used a double ended brake adjuster with a sock over the s**** portion to slowly work around the perimeter. The old original 16" stainless were a lot easier to remove (imho) and they didn't dig into the paint as bad as the repo's seem to do.
  7. ClearSpot
    ClearSpot
    from Michigan
    If you can get an area started with the bent screwdriver or gasket s****er,try doing the rest of it with sections of wood paint stir sticks.Your less likely to damage them with wood.
  8. aircap
    aircap
    X 2 on that.
  9. G'day, I have used a Snap On hubcap removal tool for years. Wide end with a good angle. If I am doing something very special I'll put a layer of masking tape on it for each ring. Haven't damaged one yet, knock on wood.
    ms
  10. Weasel
    Weasel
    I use these - non marring s****er set from Harbor Freight - one of the truly great tools they offer and a steal at $12.99 for the set of four. I use them to pry or remove anything which has a delicate finish including hub caps and trim rings. I round the corners with a sander to eliminate the pointed edge....
    www.harborfreight.com/4-piece-nonmarring-s****er-set-95832.html
  11. rusty1
    rusty1
    ...I've always used a carpenters claw hammer.
