Technical How to remove window glass?
Discussion in 'The Hokey Ass Message Board' started by tomdoodle, Nov 22, 2020.
  1. tomdoodle
    tomdoodle
    I have a 1946 International truck with a cracked driver's side window gl***. I know, that is part of being a old truck but I would like to change it anyhow. I have seen on U-Tube where this guy changes one on a 1947. He shows that the lower channel has detent holes that you go to and the channel comes right out. Well the '46 doesn't have that option. So, I need some suggestions on how to get this gl*** out. Any help will be greatly appreciated.
  2. Dave Mc
    Dave Mc
    Roll the window up about 3/4 . use 2 inch tape on to the gl*** on both sides over the top of the door frame to keep the window up while you remove the winder mechanism then with all the screws out of the winder , slide it back and forth to remove the arms from the channel , window will be free to remove from the door . reverse process to install
  3. 56don
    56don
    Or....use a ball peen hammer...:eek:
    HotRod33 and Deuces like this.
  4. Deuces
    Deuces
    Woogeroo and lothiandon1940 like this.
  5. Street_Sinner13
    Street_Sinner13
    This is helpful thanks!
