Technical How to remove window tint
Discussion in 'The Hokey Ass Message Board' started by Chaz, Mar 23, 2017.
  1. Chaz
    Chaz
    There's tinting (really dark) on the side windows of my latest project. You can tell it is not original to the window. How do I remove this ****? I hate tinted windows.
  2. junkyardjeff
    junkyardjeff
    Razor blades and gl*** cleaner.
    X-cpe likes this.
  3. Heat gun on "low" should soften the glue.
  4. If it's film, just peel and clean. If it's the spray-on ****, solvent.... lots of solvent...
  5. Heat gun helps for sure. Then use some brake cleaner or solvent if needed.
    Here Ontario makes us measure front window tint for safety. We've had to remove tint often, where we used to not have to.
    It's not that hard. Doesn't take too long with heat gun
  6. gene-koning
    gene-koning
    With a hammer and new gl***?
  7. I once bought an old Bronco for $500. I had my three boys go at it with razor blades and a heat gun, and it took them three days. Pain in the ***, but it worked. My oldest boy drives it to this day.
  8. Not sure what good a heat gun does. Seems like it would make it gooey-er and harder to deal with .
    Razor blade in a holder, then surface or gl*** cleaner, as stated earlier. The stuff goes on with water. the glue will come off the same way....in MY experience.
    Hemiman 426 likes this.
  9. rdscotty
    rdscotty
    from red deer
    Its been a few years and my first information was slightly off.
    Speedys Garage right after me has it exactly right.
  10. I use ammonia in a spray bottle , spray it on, wait a few minutes and the tint will peel off with little effort, spray again and use a razor blade to remove glue, then a good window cleaner
  11. Greenblade
    Greenblade
    I removed tint off of my friends beetle once. Used a razor and a heat gun. It took forever, but it got the job done
  12. Bandit Billy
    Bandit Billy
    I bought a T/A to restore that had that **** on every window. I removed the gl*** (as part of the restoration) and used spray on vinyl remover, the stuff you use to remove "wood" paneling from a station wagon. It leaves a glue residue behind that cleaned right up with solvent. This worked even on the back gl*** with those defroster lines on the inside of the gl*** without ruining the elements (where razor blades and s****ers would not have been as effective).
    Desoto291Hemi and mrspeedyt like this.
  13. Mr48chev
    Old thread but I'd have to think that how hard it is to get off depends a lot on who put it on and the quality of the film they used. It took me a lot of work to get it off the windows of my OT daily driver. The car had all the other side of the tracks nonsense on it when I bought it, Tinted windows, cheapie smoked taillights and horrid headlights that I still haven't changed.
  14. mrspeedyt
    mrspeedyt
    I tried to remove a low portion of the rear window plastic tint on my OT Prius and it’s been a real *****. I can’t see out of that ******** window with that heavy tint on there. thank goodness my 41 Cadillac doesn’t have a bit of added tint on it.
    deathrowdave likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    man, there sure are a rash of 5 and 10 year old threads being bumped back to the top lately, I am quite sure that Chaz got his tint off many years ago, and he has p***ed away so he really doesn't care now....
    LOST ANGEL and guthriesmith like this.
  16. hemihotrod66
    hemihotrod66
    Mine would have to be with a hammer....Real tinted gl*** not a film on the windows...
  17. theHIGHLANDER
    theHIGHLANDER
    I'll play zombie post too for the benefit of others. You need some drop cloth plastic sheet or a trash bag and some soapy water in a spritzer bottle. I go about 1/2 tsp to a qt. Spray the tint and press the plastic on to the wet surface, then spray the plastic too. Give it 7-10 min, start a spot and patiently peel off the film. Glue comes with it. Don't ask me why it works, I don't know why but it does.
    Hnstray, 2OLD2FAST and Cosmo49 like this.
  18. twenty8
    twenty8
    Exactly. Nothing wrong with good info being added to an old thread. People still search and read this stuff if it is relevant to things they are doing now. How old is too old? What is the statute of limitations for posting on previous threads? Can someone please clarify this for all of us???:confused:
    I have some tint to remove, and will be trying the "highlander method"............;)
  19. lostone
    lostone
    from kansas
    I've heard the easiest way to remove window tint is go to like Sam's club, dollar store etc and buy 1 of those cheapy cloths steamer.
    Use the steamer to heat the tint and pull it off.
    From what I've read it works great, the trick is the steam. I guess the steam actually helps lift the glue.
    2OLD2FAST, Cosmo49 and lemondana like this.
  20. safetythird
    safetythird
    Incidentally, if you have access to a steamer, it takes it right off.
    I did a pickup I bought in about an hour.
  21. lemondana
    lemondana
    from Lincoln NE
    A steamer works great, most of the glue stays on the tint when you peel it off. There are You Tube videos on this.
  22. rusty valley
    rusty valley
    For daily drivers, I only buy rust free southern cars. They all come with ****ty tinted windows it seems. Its a ***** to get off, Google it up and you will see most of the same info posted here. I use a heat gun, and razor blades, lots of them. The last one was a compact fast back job, so you were laying in the car and working over your head. The glue was so hard, and impeded with dirt I would only get about a 6" square chunk done and a new blade was needed. I'd like to beat the **** out of people who put that **** on
    2OLD2FAST and Motorwrxs like this.
  23. lemondana
    lemondana
    from Lincoln NE
    With the steamer method, all you need are plastic razor blades. Once you start getting it moist and hot the film peels off in one big piece. By far the best, easiest way!
  24. 911 steve
    911 steve
    from nebraska
    fingernail polish remover works great on the glue residue too
  25. DK23
    DK23
    I removed old tint film by spraying it really wet with ammonia, then taping black plastic up against it to sort of seal in the ammonia. Put the car window in direct bright sunlight for an hour, keeping the tint wet with the ammonia. removed the black plastic and then the tint peeled right off. Super easy.
  26. deathrowdave
    deathrowdave
    from NKy
    Just dis OT car , heat gun , peel it , window cleaned plastic single edge blade , looked new in 30 minutes
  27. 56don
    56don
    Ok, how about removing tint film from a plexigl*** window? I have a Corvette hardtop with stick on window tint on the back window. Would a steamer work there or possibly damage the plexigl*** ?
