Technical how to replece 3 speed transmission to automatic
Discussion in 'Traditional Customs' started by Spanish Fly, Sep 18, 2013.
  1. Spanish Fly
    Spanish Fly
    :confused: look i have 53 plymouth 6 flathead 3and the3 i like to put automatic transmission help plz.
  2. fullsizejohn
    fullsizejohn
    double A.......m c o
  3. How much money do you plan on spending?
  4. FiddyFour
    FiddyFour
    damn, i just... damn
  5. 73RR
    73RR
    Not a simple swap but has been done. Check my webpages for info and the adapter.
  6. typo41
    typo41
    A possible factory adapter could be found at your airport. Airport? Yes Airplane 'tugs' were buld using flathead Plymouth 6's up to the late 60's. A thick aluminum adapter puts a big block 727 trans on the back. Mine came from the Detroit area, and even with shipping to So Cal it was less than $500.00, just a suggestion.
  7. Rusty O'Toole
    Rusty O'Toole
    Best, easiest and cheapest - sell it and buy a car with an automatic.
    If time and money are no object and you want to keep the original engine, they did use that engine with a Torqueflite automatic 1957 - 59 and with the 2 speed Powerflite 1954 - 56.
    73RR has an adapter you can use to install a newer trans, they make them for a lot of old motors.
  8. You might want to do a cost trade off replacing both engine and transmission with newer units.
    Charlie Stephens
  9. theres no auto for the 216/217. bolt in. if you wanrt a flathead and auto look for a dodge or chrysler. ot do as i did get a stock 318-904 and drive the hell out of her.
  10. Spanish Fly
    Spanish Fly
