how to swap gen to alt,54 chevy sedan
Discussion in 'The Hokey Ass Message Board' started by wanabechevyguy, Sep 8, 2013.
  1. wanabechevyguy
    wanabechevyguy
    from san diego
    I need a little help with the swap of my generator to alternator on my 54 chevy sedan , went through some of post and got some good info but most are for other applications so read more an more an now im really confused ....:cool: , but I think I got it, only problem is I read so many I lost the one that was best for my application if anyone knows and can put a link that would really help ,I have a 54 chevy sedan with original wiring still I got it this way ,no motor so I put a 65 chevy imp 283 in compleat with alt. hooked it all up and it started for me but the battery wont charge checked alt and it was bad got new one ,(same ,just a reman.3 wire)and still wont charge, I started it and pulled the pos side of batt an it turned off so I started checking it out and I think I have to redo some wiring ,if I understand this I should disconnect voltage reg. take big brn wire and connect to the dbl red wires ,take the F terminal and connect to my acc on ING switch then take the R terminal an connect to:confused: ,I read you can put behind alt but better to put farther away like a batt post( don't have one) or someplace by coil but read that may cause a problem at high speeds so can I put at starter ??, Thanks hope I havnt canfused anyone.
  2. drptop70ss
    drptop70ss
    from NY
    50's Firm likes this.
  3. wanabechevyguy
    wanabechevyguy
    from san diego
    Thanks for the help, went an got new Gen at A Z ,( used numbers you listed )and what do you know they had a wiring diagram in the box ,got my 54 going and system charging again , THANKS !!!
