how to tilt hood forward
Discussion in 'The Hokey Ass Message Board' started by chavelo, Oct 8, 2009.
  1. chavelo
    chavelo
    Want to convert the hood on my 49 chevy to open forward, does anyone make the mechanism that ya'll know of or do i have to fabricate it all?
    thanks
  2. krackerjack88
    krackerjack88
    from Fresno,Ca
    Fabricate it yourself.The right weight of gas Struts will hold it up. A bar through the lip of the hood and the front two fenders is an idea. Then throw a latch at top. Did mine and it worked out nice
  3. 5756r
    5756r
    I gotta tell you that there are alot of guys out there that will tell you that they can do it and it's either not so hot, or really, really pricey. If your fab skills are good, go to the junk yard and check out either a Buick Le Sabre with the foward tilt hood and buy the ***embly or study it. Old Saab Turbo's have 'em too. Best of luck!!!!
  4. JEPPA
    JEPPA
    57' through '59 fords had tilt forward. Maybe you could fab something up with them. I'd also grab the release mechanism at the same time.
  5. plymouth1952
    plymouth1952
    Major pain in the *** to work on your ride.
  6. newfalconowner
    newfalconowner
    from NS Canada
    i made one for my falcon, check my album for my hinge pix
    *edit- i made my whole hood/fenders tilt, probably not what your looking for,sorry
  7. chopt49
    chopt49
    This '49 was at the GG show in Pleasanton a few months back - I snapped some pics of the hood... hope this gives you some ideas.
  8. I'd want to weld the hood into one piece or add some bracing to it first I think, there seems to be a lot of flex in them, unless it's just the hinges on my car.
  9. Lunatic
    Lunatic
    from Carson,Ca.
    find a old set of weights,remove the weights and use the bar and the clamps as a start..I have seen people use them for tilt front ends..just a cheap idea
  10. newfalconowner
    newfalconowner
    from NS Canada
  11. chopt49
    chopt49
    Check this one out too - they are Pros and know what they are doing! DAMN.
    CLICK THIS LINK
  12. rhd
    rhd
    from austin tx
    if your fab skills **** auto loc makes a kit......never heard of anyone using it so i couldnt tell you about the quality i know alot of people that just use La Sabre hinges....but they were all on newer cars so im not sure how well it would work on yours
  13. newfalconowner
    newfalconowner
    from NS Canada
    wish i saw that when i was f'n with my tilt hood,lol.. im no pro by any means, jsut got it done.
  14. MEDDLER1
    MEDDLER1
    You need to look up el polackos hood on his truck.you wont find a better set up.its the only way to go.i tried to find the link but couldnt i know its here somewhere though!
  15. newfalconowner
    newfalconowner
    from NS Canada
    his link is in my tilt hood post, also a vid of it
  16. 58 Delpala
    58 Delpala
    from NC
    I know the hood designs are different but here is how I did my 55. Get a hinge from a 90-92 Buick Park Ave. and make it work for less then $50.
  17. onlychevrolets
    onlychevrolets
    Plastic Pigs all had them...and I know there's a dead Corvette somewhere you can pick one up from.
  18. zman
    zman
    from Garner, NC
    Cleanest one I've seen.
    <embed type="application/x-shockwave-flash" src="http://static.photobucket.com/flash/input.swf" style="" id="IMGTag-code" bgcolor="transparent" quality="high" name="IMGTag-code" wmode="transparent" allowfullscreen="true" swliveconnect="true" allowscriptaccess="always" flashvars="ipt=%5BURL%3Dhttp%3A%2F%2Fs206.photobucket.com%2Falbums%2Fbb93%2FELpolacko%2FMy%252063%2520Ford%2520F100%2F%3Faction%3Dview%26current%3DHoodsequence001.flv%5D%5BIMG%5Dhttp%3A%2F%2Fi206.photobucket.com%2Falbums%2Fbb93%2FELpolacko%2FMy%252063%2520Ford%2520F100%2Fth_Hoodsequence001.jpg%5B%2FIMG%5D%5B%2FURL%5D&trk=image_code_click_FULLVIEW_IMG&width=175&height=21&color=#E0E5E3&border=#141414&cont=IMGTagContainer" height="21" width="175">
  19. All the big Beemers have them, and everything unbolts, even the hinges. I think I'd go that route on my 51 Ply if I hadn't already built the tilt front end.
  20. Dreddybear
    Dreddybear
    That **** is BAD ***!
  21. ELpolacko
    ELpolacko
    If you dig through the pictures, there are a few shots of how I did the hinge system for my truck: http://s206.photobucket.com/albums/bb93/ELpolacko/My 63 Ford F100/
    I did a 55 Studebaker a while back:
    And we just wrapped up a full one piece front end on a 53 F100 that needs to get videoed. Maybe I will shoot it in the morning and show some of the bracketry we made for it too.
  22. 66Newport
    66Newport
    WE have used the Buick hinges on several low riders we've built, they work good. However, Elpolako's set up is way cleaner.
