I am building a 23 T bucket. home made frame , bucket , and a lot of other metal work. Using ealy 60's 6 cyl chevy engine & trans, older Ford rear end.Want to ***le PER POLUTION. Live in M***. How do I get a ***le so I can register.
http://www.dmv.org/ma-m***achusetts/custom-built-cars.php Registering a custom-built car in M***achusetts isn't easy. The M***achusetts Registry of Motor Vehicles is going to want to inspect the vehicle before it will issue a ***le. And to p*** the inspection, you need to be able to do***ent every part used in building the vehicle, to make sure that no stolen parts are used. Remember this if you buy used parts, especially over the Internet. No receipts, no tile or registration. It's that simple.The process works like this: Once your vehicle is ready for inspection, you should call the RMV telephone center to schedule an appointment. Make sure all of your receipts are available for the inspector. If you p*** the inspection, the inspector can issue your vehicle a VIN number, which will allow you to apply to the RMV for a ***le. You can then go through the regular ***ling, registration and inspection process. There are tons of potential traps here. If you're building a custom street rod or motorcycle, you should be doing research in advance to make sure your vehicle will p*** the inspection process and that you don't run into any unforeseen difficulties at inspection time. If you aren't part of a local custom car or vehicle club, consider joining one to help expand your knowledge base before you talk to the RMV. How Custom-built Vehicle Registration may be Changing The M***achusetts State Legislature is currently considering identical bills in the House and Senate that would change the way custom-built autos and street rods are registered and licensed in M***achusetts. The bills―H.B. 2156 and H.B. 2212―would provide for the following changes: Provide specific registration cl***es and license plates for street rods and custom-built cars. Allow a replica vehicle to be ***igned the same model year designation as the production vehicle it most closely resembles. Establish specific safety inspection procedures for street rods and custom-built cars based on criteria established by the National Street Rod ***ociation. Hold street rods and custom vehicles to equipment standards specified by law during the model year listed on the ***le of the vehicle. Exempt street rods and customs from state emissions inspections. Provide for a one-time registration fee of $25 for street rods and customs. The bill is currently being reviewed in committee and will likely come up for a vote in the fall of 2006. Contact your state legislator if you want to share support or opposition to the bill
Hey brown and down; How did the legislation HB 2156 & 2212 go? Also thank you for the good feed back. It was a pleasure to get an inteligent answer
