Technical How To Un-Polish New Ansen Sprints?
Discussion in 'Traditional Hot Rods' started by Gene's Hot Rod Parts, Apr 7, 2022.
  1. twenty8
    twenty8
    Look on the bright side, it's much easier to remove a shine than it is to apply one.............:rolleyes:
  2. indyjps
    indyjps
    Agree. If anodized or clearcoated. You need to get that off or you'll end up with a blotchy finish.
    A lye solution will strip the Anodizing, it's much more controllable than oven cleaner based on the strength of the mixture, needs to handled very cautiously.
  3. Rickybop
    Rickybop
    Sandblast from 12' 7.38" away.
    I'm kidding.
    12' 7.62" is the correct distance.
    If you know what you're doing.
  4. KenC
    KenC
    I'm in the media blast camp. Most chemical methods have some risk of over doing it. But rather than shot or gl***, I'd try walnut shell media. Less aggressive and be amped up or down with air pressure changes.
    Also good for cleaning corroded carb bodies without ruining them.
    twenty8, '28phonebooth and Deuces like this.
  5. pirate
    pirate
    from Alabama
    I’m in the media blast camp. Hard to get an even finish with chemicals unless you completely immerse the whole wheel. I think media blast gives you best opportunity to make all four wheels match. We used to soda blast aluminum/magnesium aircraft parts before rebuilding. Gives a nice smooth clean finish without removing metal and being overly aggressive.
  6. Just Gary
    Just Gary
    My Fento Gyro front runners had a spun aluminum finish and I wanted them to blend with the as-cast finish on my rear ET 5-spokes.
    I polished & taped off their lips, then had 'em gl***-beaded and sprayed with Rustoleum flat antique nickel metallic.
    lippy, Bob Lowry, AHotRod and 4 others like this.
  7. Nothing dulls a aluminum wheel like full time road use during winter.Nature has a way with aluminum.
    low down A likes this.
  8. Deuces
    Deuces
    :D:cool::D
    lostone likes this.
  9. MCjim
    MCjim
    from soCal
    Trade them to guy that wants nice, polished wheels and has a pair of ****ty ones...
    LWEL9226 likes this.
  10. I'd polish the ones you have to match, put all 4 back on, and let them "age" together.
  11. 1971BB427
    1971BB427
    from Oregon
    Ansen Sprints were never "as cast" finished. They were polished, and yours just have the typical age they got over many years. I would never blast them, and damn sure wouldn't use sandpaper of any grit to attempt to age them. Vinegar sprayed on will age them, but you'll have to test how long by doing so for a short time and rinsing. Repeat leaving it on longer until you get the age you're wanting.
    Another way to etch the surface and age them is NAPA mag wheel cleaner. It states right on the spray bottle to not let it sit more than 30 seconds or it can etch the surface and remove the shine. So you could experiment with leaving it on longer until they have the desired look.
    Hopefully these new Ansens don't have any coating to protect them! If they do nothing you put on them will change the way they look.
    427 sleeper likes this.
  12. Nailhead Jason
    Nailhead Jason
    scuff them with a grey scotch brite paint prep pad and them polish them by hand with mothers. They will have a shine that looks well maintatined for decades, not brand new polish, bright but not too bright, dull but not too dull. did this with knock off Halibrand wheels on my 51 chevy looked great. and never had to polish them again.
    '28phonebooth and Just Gary like this.
  13. Budget36
    Budget36
    I’m in the “polish the old ones” camp to match the new ones. Your car looks like it can absorb the shine without looking odd.
    Just Gary and Moriarity like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Man, I remember back in the good old days when people wanted to make things better, it seems to me like all people want to do today is figure out how to make cars and parts look ****tier than they are.... kinda sad....
    slayer, Crazy Steve, egads and 13 others like this.
  15. 1971BB427
    1971BB427
    from Oregon
    Can says, "Flat antique nickel"? So which is it?
    Just Gary likes this.
  16. Just Gary
    Just Gary
    Good catch. It's flat. Post corrected.:rolleyes:
  17. Some of us want to drive and enjoy our rigs rather than spend all of our time polishing.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    I'd rather drive a shiny clean car with polished wheels.....
  19. Dennis D
    Dennis D
    Find someone that can vaporblast them.
    ekimneirbo likes this.
  20. We do that on our older pneumatic trailers. The acid etch gives a nice light silver sheen but things stain easily after you do it the first time
  21. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I have no answer for you.....
    I just want to see more of the GT-1 flip Top.
    Carry On.
    57 Fargo and Just Gary like this.
  22. swade41
    swade41
    from Buffalo,NY
    I'm in the scotchbright camp
    Eagle One Mag wheel cleaner will also take the shine off and leave the aluminum with clean sheen
    Bead blasting leaves a different texture all together
    Then you could always polish your old rims to match the new rims
    Tman, egads, Deuces and 6 others like this.
  23. pirate
    pirate
    from Alabama
    -Brent-, jimmy six and swade41 like this.
  24. swade41
    swade41
    from Buffalo,NY
    Thanks, little sweat equity (all by hand) and time, usually I ran them with scotchbright and wd40
    I try and keep a variety of textures on hand
    kadillackid, Budget36, jay t. and 3 others like this.
  25. Paint all 4 of them white. Problem solved.
  26. Bandit Billy
    Bandit Billy
    I seem to remember an old neighbor of mine who had a neat trick to dull polished wheels, actually it was his damn dog's trick and it wasn't really so much a trick but dog piss. The only issue is it wasn't real uniform.
    alanp561 and 427 sleeper like this.
  27. theHIGHLANDER
    theHIGHLANDER
    Soda blast. Very light OEM-ish texture. But I still think shine em all up. Then paint the hole edges a contrast color...;)
  28. dirt t
    dirt t
    I'm in the polished camp.
  29. swade41 likes this.
  30. ekimneirbo
    ekimneirbo
    from Brooks Ky
    It would seem logical (to me anyway) that what needs to be done is to get the clear coat off the wheel so you just have raw aluminum exposed, and the wheel will shortly look aged. I would ask the manufacturer if they know of any product that would simply disolve the clear coat.........or would they sell you some wheels that just don't have the clear coat on them.
